Oil problem
Old Nov 19, 2009 | 08:02 AM
prvdoughnut's Avatar
Oil problem
Ok so i have had a code that says camshaft sensor A is bad so i replace it and it pops up again. so i switched the 2 cam sensors to see if it was actually the sensor that was bad. To my surprise when i pulled sensor A off there is an almost black sludge with gritty pieces in at and it has white stuff in it too. I really dont think that is good so i dont think it is the sensors anymore but something else. please help asap.
Old Nov 19, 2009 | 08:21 AM
Coblasts's Avatar
Put up a pic so that we can see what it looked like.
Sounds like to me your looking at the sensor guts,was it worn off on the end.
If it did get worn then it was either to close to the reluctor wheel or there could be something wrong with the cam as well.
If it wasnt worn then it might have something to do with a tsb or pip on that, that said the white gritty stuff is chips or flashings from when the block is made
and I dont think it is anything to worry about ,but I would like to see a good pic of it .
I will see if I can find where I read it.
Old Nov 20, 2009 | 08:58 PM
thanks for the response man ill try to get a pic of it soon.
Old Nov 22, 2009 | 09:36 AM
no the gritty stuff is in the black thick oil and there are just white streaks in it
brandon04
Oct 21, 2015 07:04 AM
717ssbalt
Oct 2, 2015 04:01 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
