outside temp doesnt show on DIC
Old Apr 12, 2011 | 10:47 PM
Drew.4L's Avatar
happened the other day. its a minor inconvenience, but it shows --- on the DIC. the mileage is still there. no CEL. there was one but my intake filter was misaligned...
Old Apr 12, 2011 | 10:49 PM
Acey's Avatar
Make sure the sensor is not unplugged. It's under your driver's side headlight, attached to the bracket. If it's just showing dashes like this -- then that's probably the case, or it's actually broken. If it's just stuck in the wrong temperature, it does that sometimes.... and it'll sort itself out.
Old Apr 13, 2011 | 08:03 AM
Drew.4L's Avatar
oh that thing! i thought it was a ground to something. lol like the horn. ill def have to look in there. i started my car this morning and the headlight didnt come on on that side, BUT it works on high beams.
Old Apr 13, 2011 | 08:06 AM
cmatthewb101's Avatar
That thing is never right for me. Never been near the correct temperature.
Old Apr 13, 2011 | 12:37 PM
Acey's Avatar
Mine is actually surprisingly accurate. Always within a few degrees of the actual temp.
Old Apr 13, 2011 | 12:40 PM
TommyP's Avatar
AWD > FWD
Mine's usually pretty accurate, but every once in a while it will get stuck on a temp that is like 20-30* off. And Drew, ya check that plug, it's really easy to forget.
Old Apr 13, 2011 | 12:41 PM
Red2.4SS's Avatar
Mine did that two winters ago but then it was -40F outside!
Havent seen it do that since. I would bet you have a loose connection or a bad sensor.
Old Apr 13, 2011 | 07:09 PM
Drew.4L's Avatar
it was unplugged lol. im dumb
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Oct 13, 2015 09:32 PM
z28addiction
Sep 28, 2015 12:03 AM
jmelton327
Sep 26, 2015 10:04 PM
