P0014 won't go away
Old 02-02-2019, 10:58 PM
cobaltssdude420's Avatar
P0014 won't go away
I installed a new head, did cams, springs and timing chain and triple checked the timing was good before I put it back together. Ever since then, I've been stuck with P0014. I replaced both intake and exhaust solenoids with no luck. Before I redo the timing, anybody face a similar problem?
Old 02-03-2019, 02:16 AM
06blackbalt's Avatar
Lsj or lnf ?
Old 02-03-2019, 02:27 AM
My bad, LNF
Old 06-10-2019, 07:37 PM
Nikolas Warejcka's Avatar
Any updates on this? A car I bought that had the head replaced and zzp stage 2 cams installed is having a similar issue. I’m getting a p0014 code and it runs rough when first started for the day. I checked timing and it is good. I also replaced the cam phaser valves and I am still having the same issues.
Old 06-10-2019, 07:38 PM
Mine is a 09 lnf.
Old 06-10-2019, 07:45 PM
Mine is a 09 lnf.
I had this issue for the longest time. Replaced the camshaft solenoids and it still kept coming back. Turns out the k04 was leaking
Old 06-10-2019, 08:07 PM
Replacing the turbo fixed the p0014 code?
Old 06-10-2019, 08:54 PM
Yeah lol. But my turbo had 160k on it. Had quite a bit of shaft play too
seeyaass
11-20-2016 11:32 AM
ssdivin
05-04-2013 04:51 PM
paintballerr78
03-26-2013 05:23 PM
lancethrustbone
01-05-2013 03:48 AM
rcarr0327
2.2L LAP Performance Tech
11-12-2011 10:11 AM
Quick Reply: P0014 won't go away
