P0102, p0113, p0171 help!
Old Oct 4, 2014 | 08:37 AM
emcheck55's Avatar
ok so I have had a P0171 Running lean code for almost a year now.
I changed out the Evap Solenoid and the MAF sensor after reading other threads on here and after each part it went off for a few weeks then came back on.
Then I started getting P0426, P0300, P0326, and I was having major misfires and power issues.
I ended up changing out the Spark Plugs, Ignition Coil Pack and the ICM and I cleaned the fuel injectors.
After all of that, the only code left was my old friend P0171.
I started getting P0113 a little while after that.
Yesterday Traction Control Warning light comes on while driving and causes the car to buck a little. Thats when I ran the codes again and saw P0102.
I know 171 and 102 are both MAF related and 113 is intake temp.
so Im assuming they are all connected to 1 issue.
I'm just not sure what the T/C Warning light that accompanies the bucking has to do with anything?
its a 2006 LS 2.2L
Thanks!
Dustonian131
Sep 23, 2015 08:03 PM
Billig ss/sc
Jan 6, 2014 10:03 PM
The Punisher
Feb 11, 2008 07:13 PM
o3nisoaso3
Jan 22, 2008 05:15 PM
silverSS
Mar 7, 2006 01:14 AM
