P0300/P0302 Misfire code HELP ME!!!
Old Apr 16, 2007 | 01:10 PM
st0rcksS's Avatar
Ok, so i guess im getting this damn misfire code on cylinder 2... im swapped out all of my plugs, still having the problem. I clear the light but it comes back on after awhile, the car stutters like absolutely crazy when im accelerating in 2nd gear until I get to about 3K rpm... anyone got any idea how I can get rid of this problem? Its killing my power to say the least.... any help ASAP would be GREAT!!!!
Old Apr 16, 2007 | 01:14 PM
SKDR112888's Avatar
swapp the coils with another cylinder and if it occurs on that cylinder than its the coil.
Old Apr 16, 2007 | 01:18 PM
RG4's Avatar
RG4
Yea im having same thing happiend to me . is it only when u go wot.
Old Apr 16, 2007 | 01:20 PM
RaineMan's Avatar
Wouldn't swapping the coils be really bad? They'll be firing out of order then... not good... you'll definately get a code then anyways.
Old Apr 16, 2007 | 01:55 PM
RG4's Avatar
RG4
i think he means unpug them and then switch them
Old Jun 15, 2015 | 09:18 AM
Thomas L Edwards's Avatar
Yeah I'm having the same issue. Mines idles normally but when you go to give it gas, it sputters really bad and the CEL flashes. Spark plugs are fine, boots and coils are good. Running out of ideas tho
Old Jun 16, 2015 | 02:37 AM
megaman311's Avatar
sounds like spark blow out, did you change anything on your car in the last few months? Smaller pulley on supercharger perhaps?
Old Jun 16, 2015 | 04:55 AM
I have an SS/TC and I upgraded the intercooler piping and a 50/50 diverter valve. I took the diverter valve off yesterday and put the stock ont back on and it helped a lil, but now I can drive it just can't go sudden WOT or over 80 without backfires. And the backfires are smokeless.
Old Jun 16, 2015 | 03:45 PM
megaman311's Avatar
What plugs are you running?
Old Jun 16, 2015 | 03:50 PM
Sl0wbaltSS's Avatar
Could be coils. Try different ones.
Old Jun 16, 2015 | 05:59 PM
I forget the brand but they're platinum plugs
Old Jun 16, 2015 | 06:01 PM
Tried moving the coils around and still the same. It's not throwing a code anymore but it's definitely a lean backfire. I think I'm going to change the plugs again and all coils.
Old Jun 16, 2015 | 06:06 PM
megaman311's Avatar
Don't change the coils. Check for rust under the coil when the boot and resistor sits. Assuming they are lnf coils. Go one step colder on plugs.
Old Jun 16, 2015 | 06:11 PM
Okay, will try that. I took of the 50/50 diverter valve and put the stock one back on. It runs a lil better, only sputters and backfires at sudden throttle, WOT, or over 80mph.
Old Jun 18, 2015 | 01:37 PM
megaman311's Avatar
Yeah, sounds like spark blow out.
Old Jun 18, 2015 | 02:25 PM
Here is your problem. Get ACDelco stock plugs, the LNF is picky.
Not sure what you mean by a 50/50 diverter valve
Old Jan 23, 2018 | 08:30 AM
Juan SS's Avatar
That was the problem?
Old Jan 23, 2018 | 08:35 AM
Juan SS's Avatar
How to repair the problem? The same thing happens to me in my Cobalt ss / tc 2009 ...
Old Jan 23, 2018 | 10:46 AM
exninja's Avatar
What spark plugs do you have? What is their gap?
Old Jan 23, 2018 | 10:51 AM
double clutch's Avatar
Swap your coils. See if it moves.
Old Jan 23, 2018 | 11:12 AM
Juan SS's Avatar
Change place coils and place spark plugs, but keep coming out fault in cylinder # 2
I have spark plugs NGK IX iridium I do not know the gap
Above says you should take AC DELCO 41-108 will you have to see?
Old Jan 23, 2018 | 11:22 AM
exninja's Avatar
Try stock plugs, or at least reduce the gap on those plugs. Lots of people have issues running other than stock.
Old Jan 23, 2018 | 11:37 AM
Juan SS's Avatar
But, these are the ones you should use? ACDELCO 41-108? and how much gap?
before changing to ngk I had this same fault because the spark plugs I had no longer served, change to ngk and it worked but 2 days ago the cylinder # 2 started to give problems (it is worth mentioning that the spark plugs changed them a little over a week ago)
Old Jan 24, 2018 | 07:43 AM
sixgear's Avatar
I just went through this with swapping coils and plugs but misfire stayed with #3, Problem was bad injector
This was my post:
https://www.cobaltss.net/forums/08-1...-boost-325270/
turbochargedss2012
Sep 20, 2023 12:17 PM
ernnyyes
Oct 2, 2015 05:16 PM
717ssbalt
Oct 2, 2015 04:01 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
