p0300 with a twist
I have had the same problem Idle is bouncing and its throwing P0300 multiple missfire, after installing the new stage 3 from zzp so I re gaped the plugs to .035 and cleaned the TB and it seems to have fixed both the idle and that damn light. for all you with those problems its a ten min job thats worth a try.
its not the injectors, i got em checked out. the inj are running
optimal, ohms and the whole works. so it falls on working on the
tune. i have cleaned the maf,tb,sc,inj,autolites and i cant think of anything else beside check the ground on the engine.
