P0352 driving me crazy!!! Please Help!!!
So I had noticed my car wasn't running right a long time ago. The car now has 120k+ miles on it. . . this started since about 80k but had never gotten a code until now!! Ridiculous right!!!?? The car stutters during acceleration, heavier at take off, when trying to maintain a steady pace, it jerks quite hard due to the misfire. Well, I replaced the coil as the code says its a circuit, so I thought the coil went bad. Still have the same problem. I've gotten a multi-meter and tested for continuity and looks good from the coil connector all the way down to the PCM connector. May the PCM have a bad coil driver? Has anyone else experienced this?
Would a bad connection make a module go bad? I tested the coils and they all give the same readings. I think it may be the harness. Has anyone ever had trouble with a coil harness?
importkiller
Sep 30, 2015 07:18 PM
