P0420?
Old Jul 15, 2008 | 03:55 PM
Jesse_Chouinard's Avatar
Originally Posted by BOOSSTED 06
crank sensor case relearn, that you have to take it to some one with a tech2
Thanks man!
Old Jul 15, 2008 | 04:09 PM
BOOSSTED 06's Avatar
Originally Posted by Jesse_Chouinard
Thanks man!
no problemo
Old Jul 23, 2008 | 01:12 PM
BCobaltSS's Avatar
Just threw this today. It happened when I headed out of my garage. I checked it at murrays and cleared it . P0420 2 times. I cleared it and it has not come on yet in the 2 mile stretch.under hard accel or decel. I have had my HI FLOW down pipe by XTC on since November of 2007. No problems. I did however just switch back from my GM Stage 3 ECU tot he stock Stage 2 tune ECU last wednesday. We'll have to see if this fixes the problem by it being hotter out. A friend of mine at work said that with the moisture in the air and the change in the climate that this might have tripped it . He said don't worry about unless it comes backa again.
The guy i bought the down pipe from told me about the spacer that you put in place to prevent this from tripping as well.
I tried full throttle and the boost did not go past the normal level like it would if the cat was clogged.
So I will rule out the cat . I'll just have to wait and see . Tripping this code? will it cause the gas mileage to go down the tubes?
SSinPA
Jul 9, 2010 08:56 AM
SprChrg4Life
Jun 20, 2010 03:15 PM
XgunsmokeX
Aug 15, 2009 03:52 PM
jpunishment
Dec 11, 2007 10:48 PM
rollingboostedss
Jan 24, 2007 11:52 PM
