p1112 p1113 BOOST LEAK
Old 05-22-2011, 11:07 AM
minizr1's Avatar
Everyone. my 06 ss/sc is throwing p1112 and p1113, and my boost just dropped by like 4 or 5 psi's. HELP!!!!!!!
Old 05-22-2011, 01:48 PM
CanadianCobalt's Avatar
Lets start at the basics,
Can you hear a boost leak? Did you try the boost bypass mod? What's your vacuum at idle? And what are your mods?
Joel
Old 05-22-2011, 04:34 PM
minizr1's Avatar
i cant hear the boost leak. how would i do the boost bypass?
Old 05-22-2011, 04:47 PM
minizr1's Avatar
im at a 15psi @ idle
Old 05-23-2011, 08:34 AM
minizr1's Avatar
Joel
i did do the boost bypass and still 10 lbs. on a 2.8 pulley???? wtf???
Old 05-23-2011, 08:45 AM
madmark's Avatar
you mean -15hg?
check all the vaccum lines for cracked or torn lines, then maybe the boost bypass
Old 05-23-2011, 02:23 PM
minizr1's Avatar
Originally Posted by madmark
you mean -15hg?
is the boost bypass where the bottom vac hose from the actuator meets the top nipple of that little box?
Old 05-23-2011, 02:53 PM
-15 at idle is pretty low in HG.
I'm assuming you also just recently installed injectors and had to remove the SC?
Joel
Old 05-23-2011, 03:11 PM
revolution607@yahoo.'s Avatar
Joel
-15 is normal for our cars.
Old 05-23-2011, 03:17 PM
I've never seen it that low at idle and consistently see -18 to be the standard around the forums when this issue comes up. Where are you getting this from?
Joel
Old 05-23-2011, 03:20 PM
i usually see mine between -15 and -20.
Old 05-25-2011, 10:59 PM
minizr1's Avatar
Yes. Just installed injectors.
turbochargedss2012
09-20-2023 12:17 PM
biniecki
10-25-2015 02:23 PM
brandon04
10-21-2015 07:04 AM
tomj77
10-04-2015 11:39 AM
n20saturn
09-30-2015 12:26 AM
Quick Reply: p1112 p1113 BOOST LEAK
