P2261 on recently tuned SS TC
Old Apr 25, 2011 | 09:03 AM
Doomtor's Avatar
Hey,
Got this recently. It comes on fo a few days and goes away for a few days. Been intermitent for 2-3 weeks now.
P2261 - Turbo/Super Charger Bypass Valve - Mechanical
I have not done anything special to my car. I gpt HP tuned about a month ago or so, but we did nto make any change to the engine bay. Should I take it to the dealer and see what they say?
This morning I was driving on the highway and was noticing the car was a little "buggy" when very low boost around -1 to 1 PSI...
Any help or comment would be appreciated! Thanks a bunch!
Old Apr 25, 2011 | 09:10 AM
Chevycobaltss3's Avatar
Are u using a aftermarket bov at all.....
Old Apr 25, 2011 | 11:24 AM
Rodimus_Prime's Avatar
I get that code occassionally on the supercharged one, just ignore it, everytime ive checked the bypass is working properly
Old Apr 25, 2011 | 11:56 AM
Doomtor's Avatar
No I'm not.
My only mods are in my sig.
Is there any chance that the tune would be causing this or it definately has nothing to do with it? Because I've never seen this CEL until a few days after I got tuned.
Old Apr 25, 2011 | 01:00 PM
RoadconeTuning's Avatar
pull the stock bpv and see if its torn... then spend 60 for a "rebuild" or 150 for a forge... i noticed a huge difference in the reaction between the two on my car... forge ftw
Old Apr 25, 2011 | 01:02 PM
DillySS's Avatar
Forge is worth the change.
Old Apr 25, 2011 | 01:31 PM
Doomtor's Avatar
This is basically another "upgrade"? we keep the original setup but change the BPV?
And are you confident this is causing my CEL?
Old Jun 14, 2011 | 03:59 PM
ctn2mb's Avatar
I'm getting this with the Forge...
Old Jun 14, 2011 | 04:19 PM
Hmm. Ive had this happen with one of my tuned cars and issue was a torn bpv diaphram
Old Jun 14, 2011 | 04:20 PM
ctn2mb's Avatar
I have the Forge Bypass Valve.
Old Jun 14, 2011 | 04:28 PM
Red_SS/TC's Avatar
I had this code and I removed the Bypass valve tank and I haven't seen the code ever since. Look it up if its not your stock bpv.
Old Jun 14, 2011 | 04:31 PM
DoMiStIc_RuSh_06's Avatar
I'm pretty sure I had this code when my vacuum tank went out.
Old Jun 14, 2011 | 04:33 PM
ctn2mb's Avatar
See it's funny. I replaced the Evap Purge Solenoid and it ran good for a few days... then I get this code. Do you mean the Vacuum Tank?
Old Jun 14, 2011 | 04:52 PM
iboost's Avatar
this. I tore mine and got that code. I replaced the diaphragm and I was good to go.
My evap solenoid went I gota new one now though
Old Jun 14, 2011 | 04:58 PM
ctn2mb's Avatar
Well I have a aftermarket BPV. I have replaced the Purge Solenoid. So I guess its the vacuum tank. Anyone have a part number for it?
Old Jun 14, 2011 | 05:14 PM
sundevil07's Avatar
Two completely different engines with two different variances of forced induction. Your ignorance never ceases to amaze me, you go be lazy with your car but please don't post advice in any more threads.
Op pull your bpv diaphragm and check for tears, if its fine route the vacuum lines to bypass the vacuum tank and see if the problem still exists. If not pick up a new tank.
Old Jun 14, 2011 | 05:56 PM
bogalusahondakiller's Avatar
just a quick off topic question since we are on the vacume tank. does it hurt to bypass the tank all together
Old Jun 14, 2011 | 06:21 PM
ctn2mb's Avatar
as far as i know people's fuel trims get messed up.
Old Jun 14, 2011 | 06:32 PM
Fuel trims gets messed up is all....
Old Jun 14, 2011 | 06:40 PM
iboost's Avatar
if thats the case then, James when we tune for my new turbo I've bypassed the vacuum tank
Old Jun 14, 2011 | 06:42 PM
Good lol mines already bypassed Lmao
Old Jun 14, 2011 | 06:53 PM
iboost's Avatar
Lol yea the tank is still down there...I just yanked up on the hoses until they "came off"
Old Jun 14, 2011 | 06:59 PM
Lol... I did the same on my old tank on my old block as well
Old Jun 14, 2011 | 07:04 PM
ctn2mb's Avatar
so if i bypass this i wont have any issues? cause right now i have the symptoms of one thats going out lol.
Old Jun 14, 2011 | 07:12 PM
iboost's Avatar
I bypassed mine and haven't tuned for it and have no problems...
