Passenger window on 2.4l coupe
Old Aug 16, 2011 | 08:11 PM
bbowman2002's Avatar
So I have problems with my passenger window. It works in the morning but interment in the afternoon. I have replaced the motor and the switch! What else is there?..
Old Aug 16, 2011 | 08:18 PM
Coblasts's Avatar
Did you watch the operation of the tracks ,the glass could be binding.
Old Aug 16, 2011 | 08:20 PM
Yea I can roll it up and down manually. Just weird that it works fine in the morning ie: cool but not in the afternoon while hot...
Old Aug 16, 2011 | 08:51 PM
Coblasts's Avatar
Thats why I suspect the track,
What switch did you replace driver or passanger side?they are inter connected.
Old Aug 16, 2011 | 08:54 PM
pass side
Old Aug 16, 2011 | 09:00 PM
Coblasts's Avatar
Thats usually a common mistake because its the driver side that gets used the most,also its the one that gets all the rain on it.
Pull the driver side and push the connectors off and on a couple of times to clean up the contacts and see what happens.Take a look for any corrosion or discoloration of the pins as well!
Another thing as the car gets older it tends to be the wires going through the rubber tube from the door to the car body breaking from opening and closing the door for years.
Old Aug 16, 2011 | 09:52 PM
So after taking the door panel off for the hundredth time. I was wiggling the connector into the motor and it would work then stop. So I took the connector off and spread the pins out a little bit on the female side and the problem has been fixed!
Old Aug 17, 2011 | 07:53 AM
Coblasts's Avatar
Excellent,nothing like the diy high from fixing it yourself.
Old Aug 17, 2011 | 08:21 AM
09Sp0rt's Avatar
My passenger side works all the time, but it is slow as molasses compared to my drivers side :/
Old Aug 17, 2011 | 09:00 AM
Coblasts's Avatar
There all like that,
I was told by someone its because you dont use it as much but I dont know why forsure.
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
Tupp
Sep 30, 2015 08:18 PM
dieGone
Sep 23, 2015 10:20 AM
