pedal position sensor/ reduced engine power
Old Aug 17, 2012 | 04:05 PM
Av2915's Avatar
Alright so recently ive been having issues with my 05 SS. I keep getting a cel with a code for the pedal position sensor it cuts the power to the car but after its off and sits for a few minutes it goes away or engine power is restored. When i drive with the a/c on it tends to do it more frequently. Any ideas on what it could be or anyone had an issue like this? Dont really have money to take it to the dealer and the only mods right now are injen intake and magnaflow catback. Any help is appreciated . Thanks.
Old Aug 17, 2012 | 05:04 PM
Coblasts's Avatar
I would think the pedal sensors could be replaced on there own.
What is te exact code or codes?
Old Aug 17, 2012 | 05:11 PM
Av2915's Avatar
Its a p2138 for the APP sensor...i saw a service bulletin to check the PCM but the date on it seems to be ok.
Old Aug 18, 2012 | 01:42 AM
Soofisahab's Avatar
You might have broken the pedal housing...I mash my pedal real hard and the car would cut out on me when accelerating hard. Broken pedal housing was allowing throttle position sensor out of range (two in housing). Replaced pedal and good! Is the serious pita to replace, hardly any room. Had me wondering what bad I did in life to get to that contorted, uncomfortable position only able to get one click on the rachet at a time on super long bolts!
Old Aug 18, 2012 | 01:04 PM
Av2915's Avatar
Its a possibility i tend to get a heavy foot now and then ill get under and check it out. Im also going to check all the wiring make sure theres nothing loose.
Old Aug 18, 2012 | 01:39 PM
Jdam8139's Avatar
It could also be a bad TB. I had this same issue, and bought the pedal assembly and a new TB to be safe. Swapped out the TB and everything worked fine.
Old Aug 18, 2012 | 02:27 PM
nhanson's Avatar
Check TB and its connection
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
ernnyyes
Oct 2, 2015 05:16 PM
SSLOW06
Oct 1, 2015 07:21 PM
Stuff
Oct 1, 2015 05:47 PM
patooyee
Oct 1, 2015 01:07 PM
