Piston
Old Sep 13, 2009 | 06:58 PM
SILVER_SS/SC's Avatar
Piston
im curious how do you tell if you have a bad piston?
Old Sep 13, 2009 | 07:01 PM
damien's Avatar
Compression test
Old Sep 13, 2009 | 07:03 PM
ok thanks
Old Sep 14, 2009 | 01:37 AM
oopsitouchedmyself's Avatar
leakdown test......is better
Old Sep 14, 2009 | 01:38 AM
damien's Avatar
And it's harder especially for someone who's asking how to even tell somethings wrong.
Old Sep 14, 2009 | 02:16 AM
Sharkey's Avatar
a compression test can be done with a cheap compression test kit, cheaper ones can be had for $20. a leak down test, as it is more accurate, requires an expensive leak down tester and a compressor with a decent size tank.
Old Sep 14, 2009 | 02:39 AM
Cigar Hero's Avatar
Borescope, I'm not saying buy one but as I do often with specialty tools, maybe a rental?
Compression test or leak down test tells you a lot but about what? You find a bad cylinder
is it the rings, valves ,head gasket, hole in the piston? Seeing is believing sometimes.
Turbo Johnny
Feb 21, 2019 09:41 AM
hhrfreek
Jun 4, 2016 11:25 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
HEATON
Oct 16, 2015 07:21 PM
