Please help :( waterpump problem
Old Sep 18, 2010 | 03:35 AM
jacobrollins's Avatar
So I installed my header and downpipe. I started the car, and it started leaking coolant. I figured it was because of the waterpump and header touching eachother. So aftet research, I rotated the water pump to work with the headet position. I started the car, and it's still leaking. So I got under the car, and it was pouring out of the passenger side of the waterpump. My assumption is that the first time I started it, the car got so hot, it broke the seal. Has anyone had this problem? Does anyone have any experience with this? I'm so lost.
Old Sep 18, 2010 | 03:56 AM
ItalianJoe1's Avatar
The waterpump is bolted to the block, so I think you are talking about the crossover pipe on the back. It has o-rings on both ends and can be rotated normally, but it's possible you damaged one of the o-rings when you turned it. Unbolt the thermostat housing from the back of the block, take that pipe out, and check out the seals.
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
