Possbile trans problem??..
Old Mar 21, 2009 | 09:44 PM
08G5GT2.4L's Avatar
Alright well heres a lil back story, I had my car up on jack stands all day to put the front lip on and some other things. Now after all was said and done I lowered the car and drove it out on my driveway. The battery died on me cause I had my stereo on all day so I was letting it idle a bit to charge it back up... Well while idling I happen to notice a new noise. Now I have NEVER heard this before so its new, but it sounds like two pieces of metal clanging together inside one another (best way i can thin,k of to explain it). I searched all over the engine bay listening for noises and determined it was lower end. I went in the car pushed the clutch in and bam noise is gone. Let the clutch out noise is back, so I know its clutch/trans related. My dad says its the throw out bearing.. its not loud but its noticeable and now its annoying me. Chalk another problem on my glorious transmission. First it doesn't like to go in gear now it makes noise...ugh..
So now my question what the hell could it be? and has any one else experienced this??
Old Mar 22, 2009 | 09:25 AM
Coblasts's Avatar
I was at the dealers the other day and he showed me a clutch that gave the same symptoms you described and the one spring on the clutch plate had broken,Im not a tranny guy but I think they are for the throwout bearing.
Old Mar 23, 2009 | 12:13 AM
Nighthawk243's Avatar
Do you hold your clutch down at a red light? If so, it may be possible that the throwout bearing did fail.
Old Mar 23, 2009 | 11:12 AM
08G5GT2.4L's Avatar
Ugh I hope its not....
No I dont hold my clutch in a a light. I do sometimes but no more than a few seconds if im waiting then I dont, I only hold it in if its short. I dont know, I didnt hear it yesterday tho...
Old Mar 23, 2009 | 11:24 AM
JTob's Avatar
If it was the throw out bearing, it would only make noise with your clutch pedal pushed down. When you have your clutch pedal released, the throw out doesn't spin.
Old Mar 23, 2009 | 12:25 PM
383_Stroker's Avatar
x2
Old Mar 23, 2009 | 12:32 PM
no_mo_tires's Avatar
Originally Posted by 383_Stroker
x2
good to know because ALLWAYS hold it in at a red light , stop light , when I am braking sometimes .... etc i dunno its just how I learned.... is that bad?
Old Mar 23, 2009 | 01:27 PM
JTob's Avatar
Holding your clutch in constantly will wear out your throwout bearing. So if you don't want to have to repeatedly replace the bearing, its best just to go to neutral and let the clutch out if your going to be sitting at red lights or in a drivethru etc.
Jan 12, 2016 12:01 AM
Sep 27, 2015 08:53 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
