Power bog on Acceleration/low MPG's?
Old Sep 14, 2016 | 01:18 PM
WICobaltSS's Avatar
Ok, guys, I've been monkeying around the web trying to find possibilities to the problem, so I thought I'd end up asking you all.
06 Cobalt with a 2.4 auto. Upon acceleration, when I give it gas, the motor bogs down for a second or two before it kicks in. It feels like the response time should be quicker. It gets up to highway speed but when I try to pass it gives me some hesitation before going. No CEL's, idles fine, and recently changed out the plugs and coils. Fuel and air filter were just changed and oil was just changed. I'm also getting 24 mpg at best on highway.
I know it's just a 2.4, but still seems too sluggish.
Old Sep 15, 2016 | 10:57 AM
umrdyldo's Avatar
You have done most everything needed for a good tune up.
Maybe try a good fuel system cleaner for a couple tanks of gas.
Have you ever cleaned your throttle body?
What spark plugs did you use? What coils did you use? You should generally replace with only ACDelco parts Especially the coil packs
Old Sep 15, 2016 | 01:15 PM
WICobaltSS's Avatar
Thanks for the reply. I plan on doing the throttle body this weekend, along with checking the tranny fluid level, and doing a vacuum test to check for restrictions.
I used NGK Iridium plugs and Denso coils.
What's the best fuel system cleaner to use?
Old Sep 15, 2016 | 01:41 PM
Just make sure when you clean the throttle body do not move the butterfly just spray it with cleaner and leave it be
jeffreno
2.2L LAP Performance Tech
Aug 31, 2016 08:19 PM
Firefighter776
Aug 18, 2016 06:27 PM
Ryan3414
Aug 17, 2016 02:36 PM
Aug 17, 2016 12:55 AM
aebooth6
Aug 16, 2016 07:39 PM
