Problem with 3rd Gear?
Old Jul 11, 2006 | 02:49 PM
M-Dub's Avatar
Does anyone else with an SS/SC have any problems with 3rd gear feeling like its grinding when you are just crusing around in gear? When I accelerate it's almost like it's trying to slip out of gear with a low grinding noise? I'm having it checked out by the dealer anyway just seeing if anyone else has had the same problem!!!
Old Jul 11, 2006 | 11:36 PM
tiny's Avatar
i have it grind with my LS randomly, no idea why, no possible solutions from me
Old Jul 12, 2006 | 02:17 PM
cheedo's Avatar
my girlfriends ss/sc feels like its trying to come out of gear also. The dealer said it felt fine but i didnt think so. I does not grind though.
Old Jul 12, 2006 | 02:26 PM
e to the x's Avatar
I've noticed that my shifter has more movement and vibrates more in 3rd than the other gears. No grinding yet.
Old Jul 12, 2006 | 02:30 PM
VeNNy06SS/SC's Avatar
mine falls out of 5th every once in a while.......anyone else have this problem?
Old Jul 12, 2006 | 03:55 PM
red-SS's Avatar
my third gear does the exact same thing but I thought it was just me
Old Jul 12, 2006 | 04:06 PM
PlaysWitCars's Avatar
Former Cobalt Owner
No issues with any of my gears except reverse...just once in a great while when i put it into reverse it bangs/grinds when the clutch is fully engaged
Old Jul 12, 2006 | 04:50 PM
DarthDalla's Avatar
^^^ I have the same issue with reverse. and sometimes clucth fully engaged and lockout ring fully pulled up it wont go into reverse, I need to put it in first then retry reverse. But my third gear is fine.
Old Jul 12, 2006 | 04:53 PM
Grimlakin's Avatar
What I have found... Not sure why. But if I try to slip it into gear.. 1'st, Reverse from a stop and it doesn't want to go let the car roll just the smallest bit and it should slip right in. I'm not sure of the cause but I have had that multiple times.
Never had it pop out of a gear though. That I would be at the dealership for in a heartbeat.
BTW just beat 600 miles.
Old Jul 12, 2006 | 05:09 PM
lssport04's Avatar
mine does the same thing i shift into second then reverse to get it in every now and then...i think my service manager said it sounds like the clutch just isnt disengaging all the way....
Old Jul 12, 2006 | 11:08 PM
M-Dub's Avatar
Well I have just over 900 miles... And driving on the highway tonight on my way home it is doing it in 5th as well! It is like a light grinding noise... no problems shifting though, although getting into 1st is sometimes a bit difficult untill I shift into 2nd then 1st! I don't know going to the dealer tomorrow will let you know what they say!
Old Jul 12, 2006 | 11:14 PM
Hella-SS's Avatar
I have the same 3rd gear issue, and mine also grinds everynow and then going into 5th.
Old Jul 17, 2006 | 12:45 PM
Spite4U's Avatar
Those that hear a grinding while in gear and in motion, can you describe what it sounds like? I have what soulds like a grind/rattle that is intermittent but loud. It's a difficult noise to describe, but it sounds awful. Thanks for the help.
Old Jul 17, 2006 | 02:38 PM
M-Dub's Avatar
Well for me it is while I'm in gear... it is a low grinding noise (kinda' hard to describe!) but not really loud... I can more feel it in the shifter than hear it!
Old Jul 17, 2006 | 07:13 PM
Spite4U's Avatar
M-dub, next time your out on the road and driving beside a concrete divider, put your window down. I can really hear it when I do this and it sounds horrible. If you think of it, post back what it sounds like, I'd appreciate it!
Spite
Old Jul 18, 2006 | 11:46 AM
M-Dub's Avatar
I can't hear it like that! I can't even hear it when I have my windows down! I have to turn the radio off and roll up the windows and then I can barely hear it!!! I can more feel it in the shifter than anything else! I took it to the dealer and they said the 3rd gear is normal because of going in and out of load... but the 5th gear he hadn't heard of.... But they are really backed up with tranny problems, so they said it would be a few days before they could look at it!
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Fearedbynone
Apr 14, 2016 03:25 AM
biniecki
Oct 25, 2015 02:23 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
