Problem about brakes, what should i do?? Please read, need help
Old Apr 25, 2008 | 09:48 AM
2fastSS's Avatar
Ok all last night i started jackin my car up to take off the wheels off my car so i can color match my calipers... Started on the front and took of the two bolts that hold the piston in... Everytime i do this i always check my brake pads....
well come to find out there is no brake pad left, it is metal on metal and im not bullshitting you all on this one, idk how i didnt notice this...
Neway im not attempting to do this by myself, so i went out to autozone and bought a lifetime warranty of duralast front pads for the car they look much better
thing is, this is the first time the brakes on my car would be changed do i need to have my rotor resurfaced?? Or will i be ok with just payin midas or somethin like that to put on the break pads??
Please answer i need to do this by today sometime
Old Apr 25, 2008 | 09:49 AM
Dead Zen's Avatar
if it was metal to metal your rotors are prolly pretty effed. how do they look?
Old Apr 25, 2008 | 09:52 AM
2fastSS's Avatar
the rotors dont look to bad, i mean it wasnt exactly metal to metal but its pretty damn close i think i just got to the metal part.... I can see a little pad left on the bottom left but then the rest is metal... I mean i dont stop my car hard at all, and i havent felt any vibrations at all either so idk
Old Apr 25, 2008 | 09:57 AM
cmj917's Avatar
When you change the pads, pull the rotors off, and have a buddy drive you up to a brake shop (or Belle Tire) to have them check the run-out and, if possible, resurface them. It's only about $12 per rotor and ensures that everything is clean and straight preventing and premature warpage or strange wear issues.
Old Apr 25, 2008 | 10:11 AM
Coblasts's Avatar
Our car have crap rotors and are most likely no good(grooved so deep you cant resurface them within spec )
,I would buy a new set if you can afford it.
In my opinion when you resurface them they just end up warping in a short time and you have to do the job again.
Old Apr 25, 2008 | 10:36 AM
2fastSS's Avatar
well if i dont resurface them will i be ok??
Old Apr 25, 2008 | 10:41 AM
lil_kano's Avatar
just get some decent aftermarket ones. you'll be happy you did.
Old Apr 25, 2008 | 10:42 AM
Bades's Avatar
max..... ur best bet is to by a new set of rotors.. but i told u if u *** by the shop bring ur rotors n ill c if i can cut them.... and while ur here u can get my piston depressor.... ill explain how to use it and all.... then go home n put them on...
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
DocSvensk
Sep 27, 2015 02:24 PM
