Problem idle after WATER/METH use
Old May 29, 2008 | 09:22 AM
sound26's Avatar
Canada Problem idle after WATER/METH use
k more good New explanation
-first test used a big nozzle water/meth which is to place between the TB and the SC now use small nozzle whit selenoid!
-My engine continued to run after to have closed the key!!
-Now my idle jumps has 1200 rpm to 900 ...
- but to 1400 rpm it"s ok .......Why
need help .....
DTS?
MAF?
CAM?
TIMING?
TB?
have stage 5
2.5 pulley
s/c porting
spacer phonelic
60 injector
hp tuner
stage 3 dual end plate 15lb tank
k&n intake
gmpp manifold
aem water /meth 2 day ago
Old May 29, 2008 | 09:40 AM
rrutter81's Avatar
Originally Posted by sound26
900 RPM IS OK. BUT..
i puch gaz pedal to 1200 rpm and up-down to 900 no stable i don t understand...
it trouble start after use a water/alcool 60% in my car .
for first test i used a medium injector .......errorrr when i turn off my engine after the small run . it continu run to 2 seconde lolll not good??? . sorry for my english :P
need help .....
DTS?
MAF?
CAM?
TIMING?
TB?
have stage 5
2.5 pulley
s/c porting
spacer phonelic
60 injector
hp tuner
k&n intake
gmpp manifold
Someone please translate
Old May 29, 2008 | 09:42 AM
06black's Avatar
uh huh.
cant help those whom i cant understand.
Jesse_Chouinard's Avatar
He means his RPMs jump up and down...then he said he shut his car off and it continued to run for 2 secs. after meth use.
Old May 29, 2008 | 10:05 AM
rrutter81's Avatar
sounds like someone slapped some meth injection without a tune and is wondering why the computer doesnt like it.
Old May 29, 2008 | 10:08 AM
Werewolf SS's Avatar
Actually it sounds like your
1.) spraying to big an injector nozzle
and
2.) The meth is turning on at that rpm which is way to low to be spraying meth.
You want meth to spray above 3000 rpms imo.
Where in the intake are you spraying?
Old May 29, 2008 | 10:33 AM
sound26's Avatar
New explanation . go up
im french sorry
i have AEM water\meth
and boost controler to 12 psi start
help
hacadacalopolis
Oct 28, 2015 06:09 PM
tomj77
Oct 4, 2015 11:39 AM
jimbofug007
Oct 2, 2015 12:06 PM
nathan112i
Sep 30, 2015 07:12 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
