Question on check engine light?
So Just got my hahn intake and injen charge piping installed and I got a check engine light. I am running the GM stage 1 tune, and didn't really expect to get a light with just those upgrades. Anyone have any insight/experience with this?
did you unplug the battery before installing the parts? did you remember to plug the MAF in? have you had the CEL scanned yet to see what the error code is? Until you find out what the CEL says, it could be 5 million possibilities.
Start with the first one, then work your way down.
B0012 Driver Frontal Deployment Loop Stage 1 -SDM
B0013 Driver Frontal Deployment Loop Stage 2 -SDM
B0015 Left Front Seat Belt Pretensioner Deployment - SDM
B0016 Left Roof Rail Deployment Loop SDM
B0019 Passenger Frontal Deployment Loop Stage 1 SDM
B0020 Passenger Frontal Deployment Loop Stage 2 SDM
B0022 Right Front Seat Belt Pretensioner Deployment SDM
B0023 Right Roof Rail Deployment Loop SDM
B0052 Deployment Commanded SDM
B0053 Deployment Commanded with Loop DTCs present SDM
B0081 Passenger Presence System SDM
B0083 Front End Sensor SDM
B0085 Left Front Side Impact Sensor SDM
B0086 Right Front Side Impact Sensor SDM
B0158 Outside Air Temperature Sensor BCM HVAC
B0285 Electric Rear Defrost Circuit Low BCM
B1000 Electronic Control Unit (ECU) Performance- BCM, DRR, IPC, Radio, SDM, VCIM
B1001 Option Configuration Error BCM, DRR, Radio,SDM,VCIM
B1004 Electronic Control Unit Identification Circuit BCM, DRR, IPC
B1009 EEPROM Checksum Mismatch BCM, Radio
B1019 System Configuration Error SDM
B1025 LF Audio Output Circuit Radio
B1035 RF Audio Output Circuit Radio
B1045 LR Audio Output Circuit Radio
B1055 RR Audio Output Circuit Radio
B1325 Device Power 1 Circuit BCM, IPC, Radio, SDM
B1370 Device Ignition 1 Circuit BCM, SDM
B1380 Device Ignition ACCESSORY Circuit- BCM
B1441 Device Ignition OFF, RUN, and CRANK Circuit- BCM
B1480 Battery Rundown Protection Circuit BCM
B1516 Battery Current Sensor Performance BCM
B1517 Battery Voltage BCM
B2455 Cellular Phone Microphone Circuit Malfunction VCIM
B2470 Cellular Phone Antenna Circuit Malfunction VCIM
B2476 Cellular Phone Select Service Switch Malfunction VCIM
B2482 Cellular Phone Select Switch Range/Performance VCIM
B2483 GPS Sensor Circuit Low VCIM
B2484 GPS Sensor Circuit Open VCIM
B2530 Front Fog Lamps Control Circuit BCM
B2580 Headlamp High Beam Control Circuit BCM
B2625 Display Dimming Pulse Width Modulation (PWM) Output Circuit BCM
B2645 Ambient Light Sensor Circuit BCM
B2705 Gearshift Unlock Circuit BCM
B2750 Horn Relay Coil Circuit BCM
B2961 Key In Ignition Circuit - BCM
B3031 Security System Controller In Learn Mode BCM
B3055 No Transponder Modulation or No Transponder BCM
B3060 Unprogrammed Transponder Identification Code Received BCM
B3100 Keyless Entry Data Link Circuit BCM
B3109 Keyless Entry Transmitter Low Battery BCM
B3127 Left Front Door Only Unlock Circuit Low BCM
B3132 All Door Unlock Circuit Low BCM
B3137 All Door Lock Circuit Low BCM
B3265 Trunk Release Output Circuit BCM
B3715 Front Wiper Relay Drive Circuit BCM
B3716 Front Wiper Relay Drive Circuit Range/Performance BCM
B3717 Front Wiper Relay Drive Circuit Low BCM
B3718 Front Wiper Relay Drive Circuit High BCM
B3719 Front Wiper Relay Drive Circuit Open BCM
B3794 Cruise Control Function Request Circuit BCM
B3903 Stop Lamp Relay Circuit BCM
B3935 Transponder Authentication Error BCM
B3948 Left Front Turn Signal Circuit BCM
B3949 Right Front Turn Signal Circuit BCM
B3950 Left Rear Turn Signal Circuit BCM
B3951 Right Rear Turn Signal Circuit BCM
B3976 Unconfigured Transponder BCM
C0000 Vehicle Speed Information Circuit - PSCM
C0035 LF Wheel Speed Sensor Circuit EBCM
C0040 RF Wheel Speed Sensor Circuit EBCM
C0045 LR Wheel Speed Sensor Circuit EBCM
C0050 RR Wheel Speed Sensor Circuit EBCM
C0110 Pump Motor Circuit EBCM
C0116 Pump Motor Relay Circuit EBCM
C0121 Valve Relay Circuit EBCM
C0161 ABS/TCS Brake Switch Circuit EBCM
C0176 System Thermal Error PSCM
C0220 Left Front ABS Channel in Release Too Long EBCM
C0221 Right Front ABS Channel in Release Too Long EBCM
C0228 Left Rear ABS Channel in Release Too Long EBCM
C0229 Right Rear ABS Channel in Release Too Long EBCM
C0240 PCM Traction Control Not Allowed EBCM
C0242 PCM Indicated TCS Malfunction EBCM
C0281 Dynamic Rear Proportioning (DRP) Performance EBCM
C0475 Electric Steering Motor Circuit PSCM
C0545 Steering Wheel Torque Input Sensor PSCM
C0550 Electronic Control Unit (ECU) Performance EBCM
C0552 Improper Shutdown EBCM
C0561 System Disabled Information Stored EBCM
C0845 Device Ignition 1 Circuit PSCM
C0895 Device Voltage PSCM
C0899 Device Voltage Low EBCM
C0900 Device Voltage High EBCM
P0010 Intake Camshaft Position (CMP) Actuator Solenoid Control Circuit ECM
P0011 Intake Camshaft Position (CMP) System Performance ECM
P0013 Exhaust Camshaft Position (CMP) Actuator Solenoid Control Circuit ECM
P0014 Exhaust Camshaft Position (CMP) System Performance ECM
P0016 Crankshaft Position (CKP) - Intake Camshaft Position (CMP) Correlation- ECM
P0017 Crankshaft Position (CKP) - Exhaust Camshaft Position (CMP) Correlation - ECM, PCM
P0030 HO2S Heater Control Circuit Sensor 1 ECM, PCM
P0033 Supercharger Bypass Valve Solenoid Control Circuit PCM
P0036 HO2S Heater Control Circuit Sensor 2 ECM, PCM
P0053 HO2S Heater Resistance Sensor 1 ECM
P0054 HO2S Heater Resistance Sensor 2 ECM
P0068 Throttle Body Airflow Performance ECM, PCM
P0069 Manifold Absolute Pressure - Barometric Pressure Correlation PCM
P0097 Intake Air Temp Low Voltage PCM
P0098 Intake Air Temperature (IAT) Sensor 2 Circuit High Voltage PCM
P0101 Mass Air Flow (MAF) Sensor Performance ECM, PCM
P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency ECM, PCM
P0103 Mass Air Flow (MAF) Sensor Circuit High Frequency ECM, PCM
P0106 Manifold Absolute Pressure (MAP) Sensor Performance ECM, PCM
P0107 Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage ECM, PCM
P0108 Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage ECM, PCM
P0112 Intake Air Temperature (IAT) Sensor 1 Circuit Low Voltage ECM, PCM
P0113 Intake Air Temperature (IAT) Sensor 1 Circuit High Voltage ECM, PCM
P0116 Engine Coolant Temperature (ECT) Sensor Performance. ECM
P0117 Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage ECM, PCM
P0118 Engine Coolant Temperature (ECT) Sensor Circuit High Voltage ECM, PCM
P0120 Throttle Position (TP) Sensor 1 Circuit ECM, PCM
P0121 Throttle Position (TP) Sensor 1 Performance ECM, PCM
P0122 Throttle Position (TP) Sensor 1 Circuit Low Voltage ECM, PCM
P0123 Throttle Position (TP) Sensor 1 Circuit High Voltage ECM, PCM
P0125 Engine Coolant Temperature (ECT) Insufficient for Closed Loop Fuel Control - ECM, PCM
P0128 Engine Coolant Temperature (ECT) Below Thermostat Regulating Temperature ECM, PCM
P0130 HO2S Circuit Sensor 1 ECM, PCM
P0131 HO2S Circuit Low Voltage Sensor 1 ECM, PCM
P0132 HO2S Circuit High Voltage Sensor 1 ECM, PCM
P0133 HO2S Slow Response Sensor 1 ECM, PCM
P0134 HO2S Circuit Insufficient Activity Sensor 1 ECM, PCM
P0135 HO2S Heater Performance Sensor 1 ECM, PCM
P0136 HO2S Circuit Sensor 2 ECM, PCM
P0137 HO2S Circuit Low Voltage Sensor 2 ECM, PCM
P0138 HO2S Circuit High Voltage Sensor 2 ECM, PCM
P0140 HO2S Circuit Insufficient Activity Sensor 2 ECM, PCM
P0141 HO2S Heater Performance Sensor 2 ECM, PCM
P0171 Fuel Trim System Lean ECM, PCM
P0172 Fuel Trim System Rich ECM, PCM
P0201 Injector 1 Control Circuit ECM, PCM
P0202 Injector 2 Control Circuit ECM, PCM
P0203 Injector 3 Control Circuit ECM, PCM
P0204 Injector 4 Control Circuit ECM, PCM
P0218 Transmission Fluid Overtemperature TCM
P0220 Throttle Position (TP) Sensor 2 Circuit ECM, PCM
P0222 Throttle Position (TP) Sensor 2 Circuit Low Voltage ECM, PCM
P0223 Throttle Position (TP) Sensor 2 Circuit High Voltage ECM, PCM
P0230 Fuel Pump Relay Control Circuit ECM, PCM
P023A Charge Air Cooler (CAC) Coolant Pump Relay Control Circuit PCM
P0300 Engine Misfire Detected ECM, PCM
P0315 Crankshaft Position (CKP) System Variation Not Learned ECM, PCM
P0324 Knock Sensor (KS) Module Performance ECM
P0325 Knock Sensor (KS) Module Performance ECM, PCM
P0326 Knock Sensor (KS) Performance ECM, PCM
P0327 Knock Sensor (KS) Circuit ECM, PCM
P0328 Knock Sensor (KS) Circuit ECM
P0335 Crankshaft Position (CKP) Sensor Circuit ECM, PCM
P0336 Crankshaft Position (CKP) Sensor Performance ECM, PCM
P0340 Intake Camshaft Position (CMP) Sensor Circuit ECM, PCM
P0341 Camshaft Position (CMP) Sensor Performance ECM, PCM
P0351 Ignition Coil 1 Control Circuit ECM
P0352 Ignition Coil 2 Control Circuit ECM
P0353 Ignition Coil 3 Control Circuit ECM
P0354 Ignition Coil 4 Control Circuit ECM
P0365 Exhaust Camshaft Position (CMP) Sensor Circuit ECM
P0366 Exhaust Camshaft Position (CMP) Sensor Performance ECM
P0411 Secondary Air Injection (AIR) System Incorrect Air Flow Detected ECM
P0412 Secondary Air Injection (AIR) Solenoid Control Circuit ECM
P0418 Secondary Air Injection (AIR) Pump Control Circuit ECM
P0420 Catalyst System Low Efficiency ECM, PCM
P0442 Evaporative Emission (EVAP) System Small Leak Detected ECM, PCM
P0443 Evaporative Emission (EVAP) Purge Solenoid Control Circuit ECM, PCM
P0446 Evaporative Emission (EVAP) Vent System Performance ECM, PCM
P0449 Evaporative Emission (EVAP) Vent Solenoid Control Circuit ECM, PCM
P0451 Fuel Tank Pressure (FTP) Sensor Performance ECM, PCM
P0452 Fuel Tank Pressure (FTP) Sensor Circuit Low Voltage ECM, PCM
P0453 Fuel Tank Pressure (FTP) Sensor Circuit High Voltage ECM, PCM
P0454 Fuel Tank Pressure (FTP) Sensor Intermittent ECM, PCM
P0455 Evaporative Emission (EVAP) System Large Leak Detected ECM, PCM
P0461 Fuel Level Sensor Performance ECM, PCM
P0462 Fuel Level Sensor Circuit Low Voltage ECM, PCM
P0463 Fuel Level Sensor Circuit High Voltage ECM, PCM
P0464 Fuel Level Sensor Circuit Intermittent ECM, PCM
P0480 Cooling Fan Relay 1 Control Circuit ECM, PCM
P0481 Cooling Fan Relay 2 Control Circuit ECM, PCM
P0482 Cooling Fan Relay 3 Control Circuit ECM, PCM
P0496 Evaporative Emission (EVAP) System Flow During Non-Purge ECM, PCM
P0502 Vehicle Speed Sensor (VSS) Circuit Low Voltage ECM, PCM
P0503 Vehicle Speed Sensor (VSS) Circuit Intermittent ECM, PCM
P0506 Idle Speed Low ECM, PCM
P0507 Idle Speed High ECM, PCM
P0520 Engine Oil Pressure (EOP) Sensor Circuit ECM, PCM
P0532 (A/C) Air Conditioning Pressure Sensor Circuit Low Voltage ECM, PCM
P0533 (A/C) Air Conditioning Pressure Sensor Circuit High Voltage ECM, PCM
P0562 System Voltage Low ECM, PCM, TCM
P0563 System Voltage High ECM, PCM, TCM
P0575 Cruise Control Switch Signal Circuit ECM, PCM
P0601 Control Module Read Only Memory (ROM) ECM, PCM
P0601 Transmission Control Module (TCM) Read Only Memory (ROM) TCM
P0602 Control Module Not Programmed ECM, PCM
P0602 Transmission Control Module (TCM) Not Programmed TCM
P0603 Control Module Long Term Memory Reset ECM, PCM
P0603 Transmission Control Module (TCM) Long Term Memory Reset TCM
P0604 Control Module Random Access Memory (RAM) ECM, PCM
P0604 Transmission Control Module (TCM) Random Access Memory (RAM) TCM
P0606 Control Module Internal Performance ECM, PCM
P0607 Control Module Performance ECM, PCM
P060D Control Module Accelerator Pedal Position (APP) System Performance- ECM
P062F Control Module Long Term Memory Performance ECM
P062F Transmission Control Module (TCM) Long Term Memory Performance- TCM
P0621 Generator L-Terminal Circuit ECM, PCM
P0622 Generator F-Terminal Circuit ECM, PCM
P0641 5-Volt Reference 1 Circuit ECM, PCM
P0645 Air Conditioning (A/C) Clutch Relay Control Circuit ECM, PCM
P0650 Malfunction Indicator Lamp (MIL) Control Circuit ECM, PCM
P0651 5-Volt Reference 2 Circuit ECM, PCM
P0685 Engine Controls Ignition Relay Control Circuit ECM
P0689 Engine Controls Ignition Relay Feedback Circuit Low Voltage ECM
P0690 Engine Controls Ignition Relay Feedback Circuit High Voltage ECM
P0700 Transmission Control Module (TCM) Requested MIL Illumination ECM
P0705 Transmission Range (TR) Switch Circuit TCM
P0711 Transmission Fluid Temperature (TFT) Sensor Performance TCM
P0712 Transmission Fluid Temperature (TFT) Sensor Circuit Low Voltage TCM
P0713 Transmission Fluid Temperature (TFT) Sensor Circuit High Voltage TCM
P0716 Input Speed Sensor Performance TCM
P0717 Input Speed Sensor Circuit Low Voltage TCM
P0719 Brake Switch Circuit Low Voltage ECM, PCM, TCM
P0722 Output Speed Sensor Circuit Low Voltage TCM
P0723 Output Speed Sensor Circuit Intermittent TCM
P0724 Brake Switch Circuit High Voltage ECM, PCM, TCM
P0741 Torque Converter Clutch (TCC) System - Stuck Off TCM
P0742 Torque Converter Clutch (TCC) System - Stuck On TCM
P0751 1-2 Shift Solenoid (SS) Valve Performance - No First or Fourth Gear- TCM
P0752 1-2 Shift Solenoid (SS) Valve Performance - No Second or Third Gear- TCM
P0756 2-3 Shift Solenoid (SS) Valve Performance - No First or Second Gear- TCM
P0757 2-3 Shift Solenoid (SS) Valve Performance - No Third or Fourth Gear-TCM
P0833 Clutch Pedal Switch 2 Circuit ECM, PCM
P0842 Transmission Fluid Pressure (TFP) Sensor Circuit Low Voltage TCM
P0843 Transmission Fluid Pressure (TFP) Sensor Circuit High Voltage TCM
P0961 Line Pressure Control (PC) Solenoid System Performance TCM
P0973 1-2 Shift Solenoid (SS) Control Circuit Low Voltage TCM
P0974 1-2 Shift Solenoid (SS) Control Circuit High Voltage TCM
P0976 2-3 Shift Solenoid (SS) Control Circuit Low Voltage TCM
P0977 2-3 Shift Solenoid (SS) Control Circuit High Voltage TCM
P1101 Intake Air Flow System Performance ECM, PCM
P1106 Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage- ECM
P1107 Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low Voltage- ECM
P1111 Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage- ECM
P1112 Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage- ECM
P1114 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage-ECM
P1115 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage- ECM
P1133 HO2S Insufficient Switching Sensor 1 ECM, PCM
P1134 HO2S Circuit Insufficient Activity Sensor 1 ECM
P1174 Fuel Trim Cylinder Balance ECM
P1182 Supercharger Inlet Pressure Sensor Performance PCM
P1183 Supercharger Inlet Pressure Sensor Circuit Low Voltage PCM
P1184 Supercharger Inlet Pressure Sensor Circuit High Voltage PCM
P1258 Engine Coolant Over Temperature - Fuel Disabled ECM, PCM
P1400 Cold Start Emission Reduction Control System ECM
P1516 Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance- ECM, PCM
P1574 Stop Lamp Switch Circuit ECM, PCM
P1621 Control Module Long Term Memory Performance ECM
P1629 Theft Deterrent Fuel Enable Signal Not Received ECM, PCM
P1630 Theft Deterrent Learn Mode Active ECM, PCM
P1631 Theft Deterrent Start Enable Signal Not Correct ECM, PCM
P1632 Theft Deterrent Fuel Disable Signal Received ECM, PCM
P1668 Generator L-Terminal Control Circuit ECM, PCM
P1680 Control Module Accelerator Pedal Position (APP) System Performance- PCM
P1681 Control Module Throttle Position (TP) System Performance PCM
P1682 Ignition 1 Switch Circuit 2 ECM, PCM
P1810 Transmission Fluid Pressure (TFP) Position Switch Circuit TCM
P1811 Maximum Adapt and Long Shift TCM
P1816 Transmission Fluid Pressure (TFP) Valve Position Switch Indicates Park/Neutral (P/N) with Drive Ratio TCM
P1818 Transmission Fluid Pressure (TFP) Valve Position Switch Indicates Drive without Drive Ratio -TCM
P2101 Control Module Throttle Actuator Position Performance ECM, PCM
P2119 Throttle Closed Position Performance ECM, PCM
P2120 Accelerator Pedal Position (APP) Sensor 1 Circuit ECM, PCM
P2122 Accelerator Pedal Position (APP) Sensor 1 Circuit Low Voltage ECM, PCM
P2123 Accelerator Pedal Position (APP) Sensor 1 Circuit High Voltage ECM, PCM
P2125 Accelerator Pedal Position (APP) Sensor 2 Circuit ECM, PCM
P2127 Accelerator Pedal Position (APP) Sensor 2 Circuit Low Voltage ECM, PCM
P2128 Accelerator Pedal Position (APP) Sensor 2 Circuit High Voltage ECM, PCM
P2135 Throttle Position (TP) Sensor 1-2 Correlation ECM, PCM
P2138 Accelerator Pedal Position (APP) Sensor 1-2 Correlation ECM, PCM
P2176 Minimum Throttle Position Not Learned ECM, PCM
P2227 Barometric Pressure (BARO) Sensor Performance PCM
P2228 Barometric Pressure (BARO) Sensor Circuit Low Voltage PCM
P2229 Barometric Pressure (BARO) Sensor Circuit High Voltage PCM
P2430 Secondary Air Injection (AIR) System Pressure Sensor Circuit ECM
P2431 Secondary Air Injection (AIR) System Pressure Sensor Performance- ECM
P2432 Secondary Air Injection (AIR) System Pressure Sensor Circuit Low Voltage- ECM
P2433 Secondary Air Injection (AIR) System Pressure Sensor Circuit High Voltage- ECM
P2440 Secondary Air Injection (AIR) System Shut-Off Valve Stuck Open ECM
P2444 Secondary Air Injection (AIR) System Pump Stuck On ECM
P2534 Ignition 1 Switch Circuit Low Voltage ECM
P2535 Ignition 1 Switch Circuit High Voltage ECM, PCM
P2610 Control Module Ignition Off Timer Performance ECM
P2763 Torque Converter Clutch (TCC) Pressure Control (PC) Solenoid Control Circuit High Voltage TCM
P2764 Torque Converter Clutch (TCC) Pressure Control (PC) Solenoid Control Circuit Low Voltage TCM
P2A00 HO2S Circuit Closed Loop (CL) Performance Sensor 1 ECM
P2A01 HO2S Circuit Sensor 2 ECM
U0001 High Speed CAN Communication Bus PCM
U1300 Class 2 Data Link Low PCM
U1301 Class 2 Data Link High PCM
U1305 Class 2 Data Link Low or High PCM
U1500 Inter-Device Dedicated Bus Malfunction VCIM
U2100 Controller Area Network (CAN) Bus Communication- BCM, EBCM, ECM, IPC, PCM, PSCM, Radio, SDM, TCM, VCIM
U2103 Fewer Controllers On Bus Than Programmed- IPC, Radio, SDM, VCIM
U2105 Lost Communications with Engine Control System- BCM, EBCM, PSCM, TCM
U2106 Lost Communications with Transmission Control System- BCM, EBCM, ECM
U2107 Lost Communications with Body Control System- EBCM, ECM, IPC, PCM, PSCM
U2108 Lost Communications with ABS/TCS Control System BCM
U2109 Lost Communications with Powertrain Multiple Control System EBCM
U2111 Lost Communications with Steering Control System BCM
U2113 Lost Communications with Sensing Diagnostic Module (SDM) BCM
U2116 Lost Communications with Instrument Panel Cluster (IPC) BCM
U2125 Lost Communications with Mobile Communications Control Systems- BCM
U2137 Lost Communications with Vehicle Theft Deterrent (VTD) BCM
U2172 Lost Communications with Digital Radio Receiver (DRR) BCM
023 Seat Belt Tension Sensor Circuit Out of Range PPS
024 PPS Ignition 1 Voltage Performance PPS
063 PPS Out of Calibration PPS
064 Communication/ID Performance PPS
065 Sensor Circuit Out of Range PPS
Or just get it scanned
TurboTechRacing
Oct 27, 2015 07:58 AM
