quick piston ring help!!!
Old Sep 30, 2008 | 09:48 PM
0redline6's Avatar
Exclamation quick piston ring help!!!
hey gys the bottom ring with the acoridan ring do i put the acordian facing up or down.. i would have looked on the stock one.. but well ill post pics later haha thanks for the fast response!
Old Sep 30, 2008 | 09:50 PM
BLAZIN07SS's Avatar
I'm too JDM for you
you mean the oil ring? im pretty sure thats non directional, just make sure that its not overlapping. let someone else chime in though cause i have never worked on the internals of the LSJ
Old Sep 30, 2008 | 10:06 PM
0redline6's Avatar
yea the oil ring sure! haha ok yea i will.. there isnt to much to indicate that its a directional dk lol thats y i am asking haha
16 views and noone?! lol
keep it on the top!! im doing my install right now and idk what to with it lol
Old Sep 30, 2008 | 10:08 PM
Brian MP5T's Avatar
It should be sandwiched between two small rings...
Non directional.. Take your Time..
MORE
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Oil Ring Installation
Most automobiles use three-piece oil control rings, consisting of an expander spacer in the center with two outside rails. Install them as shown in the figure below.
Installing the oil ring rail. Courtesy of Federal-Mogal Corporation.
* Install the expander spacer, being careful not to overlap its ends.
o The ends are usually painted different colors to make it obvious to the installer if they are accidentally overlapped.
o Some expanders are filled with a Teflon button on their ends to prevent improper assembly.
o In the absence of a recommendation, position the expander gap above one end of the wrist pin.
* Next, install the rails. Installing the top rail first is easiest.
o While holding your finger over the butted ends of the expander, install the top rail.
o Position its gap above the skirt on one side of the expander spacer gap.
* Install the lower rail with its gap placed above the skirt on the opposite side of the expander gap.
Old Sep 30, 2008 | 10:12 PM
0redline6's Avatar
MORE
dude thanks your a life saver!! haha i appreciate it.. ill post pics on what my stock piston looked like later haha
Old Sep 30, 2008 | 11:45 PM
RollermanDan's Avatar
Good info for sure!
Old Sep 30, 2008 | 11:58 PM
0redline6's Avatar
anyone know the tq specs to the rod cap bolt nuts?.. this is another thing now stopping me lol
Old Oct 1, 2008 | 12:10 AM
red_line_cobalt's Avatar
first off did you get new rod bolts? and bearings?
Old Oct 1, 2008 | 12:36 AM
if you dont GET THEM!!!!! you will need rod bearings... dont ever put the old ones back in.... and i hope your rist pins are new also. the rod bolts are torqued to yeild which means they stretch into place when you tighten them. so you can only use them once. your once that cam off are junk now. you can get GM replacment ones or after market... ARP has some that can withstand more power and RPMs i just got a set of these for my build. if you have the GM NEW rod bolts they must be torqued to 35 foot pounds, broken loose, and then tightened again to 35... broken lose and then tightened one last time but to 65 foot pounds this time.
Last edited by red_line_cobalt; Oct 1, 2008 at 12:36 AM. Reason: Automerged Doublepost
ineedacobaltss
Nov 7, 2015 02:25 PM
dennis69
Oct 20, 2015 07:39 AM
HEATON
Oct 16, 2015 07:21 PM
SlowSaturn
Sep 28, 2015 11:03 AM
