quick question about coolant pump
Old Mar 30, 2009 | 09:21 PM
craigk_c19's Avatar
ok i have tried everything i have read about from searching forthis but i cant tell if my pump is working or not no matter how much i put in it i cant see it in the neck and i tried to listen to it but couldnt hear anything and the only reason i think it might be working is b/c when im parked my coolant temp goes from 182 to 194+ or so and the reasson i think my pump still works is because if i raise the RPMs to about 3k and hold it there the temps drop back down to 184ish so this means my pump is working right? im fixing to get the OTTP h/e
Old Mar 30, 2009 | 09:57 PM
css9450's Avatar
Which pump are you talking about? The water pump (on the engine) or the intercooler pump? Those temps on your DIC are telling us your regular water pump is working (you'd know in a hurry if it wasn't) but the intercooler system is completely separate.
Old Mar 30, 2009 | 10:04 PM
craigk_c19's Avatar
o i thought it was readding the coolant not the water pump dang it i guess i need to go fill up my tell there is water showing the neck of the coolant
Old Mar 30, 2009 | 10:06 PM
hatrickstu's Avatar
yea im confused, you talking IC system pump or engine coolant pump?
Old Mar 30, 2009 | 10:10 PM
craigk_c19's Avatar
i talking about IC pump
Old Mar 30, 2009 | 10:19 PM
hatrickstu's Avatar
if you crawl under the car with the car running (unless you have it enabled on ACC through HPT) then you can place your hand on it and feel it running.
hatrickstu's Avatar
Old Mar 30, 2009 | 10:20 PM
hatrickstu's Avatar
Old Mar 30, 2009 | 10:52 PM
craigk_c19's Avatar
ill try that tomorrow when i go to school thanks hatrickstu!
Old Mar 30, 2009 | 11:03 PM
Dainslaif's Avatar
If your IAT2 is 190 then goes down when you give it some gas, that's normal. Fresh (cool) air is being pulled into the engine, so the temp should go down.
The most failsafe way to determine is to stick a clean drinking straw into the fill neck while the engine's running and see if it gets tossed around. Personally I don't know the difference between a working and dead pump by touch, which is why I always favor sticking something in the stream and seeing what happens.
Old Mar 30, 2009 | 11:05 PM
hatrickstu's Avatar
intake temps should never be 190 if the pump is working. thats nuts
Old Mar 30, 2009 | 11:09 PM
Dainslaif's Avatar
Agreed. I think I only got mine up that high when I was idling in the drivethrough for like 15 minutes. Maybe he was actually talking about coolant temp and not IAT2? That would explain the high numbers.
Craig, are you coming to Kileen this weekend? I'll check your pump for ya.
Old Mar 30, 2009 | 11:14 PM
hatrickstu's Avatar
thats actually a very good point. dont confuse your coolant with your iat's
Old Mar 30, 2009 | 11:22 PM
craigk_c19's Avatar
i dont have hp or an intorceptor so i was talking about the coolant temp from the DIC i will be getting dual intoceptors at the end of april and how much coolant can yall see when yall look down the neck b/c none is showing when i look down in it
Old Mar 30, 2009 | 11:29 PM
hatrickstu's Avatar
lol thats your engine coolant temp. completely unrelated. still try what i said earlier
Old Mar 31, 2009 | 12:14 AM
craigk_c19's Avatar
ill try it out in the morning and if that doesnt work ill try out the straw thing out
Old Mar 31, 2009 | 12:16 AM
craigk_c19's Avatar
ill try it out in the morning and if that doesnt work ill try out the straw thing out then
Old Mar 31, 2009 | 12:17 AM
craigk_c19's Avatar
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
grampss
Sep 27, 2015 08:51 PM
riceburner
Sep 26, 2015 12:57 AM
