Random Question - Electrical?
Old Dec 13, 2012 | 05:52 AM
06Cobalt2.4's Avatar
Okay so I started my car up and popped the hood after replacing a blown header gasket to make sure everything sounded fine, no leaks, etc..
I notice that the filter on the K&N [Short Ram/Cold Air] Intake had a visible amount of particles, not sure what they were but they looked like they were from a tree or a plant. I didn't want to pull the entire intake out to clean it, so I blew on the air filter to try and remove the unwanted particles
When I blew on the filter the first time, it shuddered, and the headlights dimmed way down, and the rpm dropped lower than my 600 idle, it sounded like it was going to die.
I was like either that hasn't happened before, or I didn't try blowing on the filter to knock big particles loose.
So I blew on it again, to see if it would happen again. Sure enough, as I exhaled for about 3 seconds in the direction of the filter from a foot away, and the car completely died. The temperature outside was somewhere in the 60's and the car had been driving during the day, so temperature wasn't the issue.
I guess I'm really just wondering if this is something that is known to occur, or what. I think it messes with the Mass Air Flow Sensor, because when I turn the car back on, It will turn t/c off, and a check engine will come on. I took it to O'Reilly Autp Parts for a diagnostic, and I believe (I'll have to check because I'm not sure) that the code was P0102. I reset my codes, and it doesn't come back on, except for some strange reason when I use cruise control between 73 and 79 mph it turns t/c off. Probably getting ready to replace it, and get a JET Performance if it doesn't eff with my Trifecta.
Any suggestions?
Old Dec 13, 2012 | 09:21 AM
Sir_Hiro's Avatar
p0102 Is a Mass Air Flow Sensor error IIRC
Old Dec 13, 2012 | 10:22 AM
prevsrt4owner's Avatar
In4thelulz.
Old Dec 13, 2012 | 10:26 AM
574's Avatar
574
I wish I got 79mpg at 73mph
Old Dec 13, 2012 | 10:27 AM
jonathan923's Avatar
am so in!
Old Dec 13, 2012 | 10:28 AM
buildmeanempire's Avatar
Just throwin it out there but... because racecar?
Old Dec 13, 2012 | 10:42 AM
PSHHH's Avatar
Gotta be, that beast is sucking in so much air now its pulling down trees.
Old Dec 13, 2012 | 10:46 AM
Old Dec 13, 2012 | 11:00 AM
Close: RACRCAS!
Old Dec 13, 2012 | 11:04 AM
Damn I knew something was a little off haha.... still not as retarded as this tool though.
Old Dec 14, 2012 | 01:51 AM
79 mph, my bad.
Solaris99
28
Mar 15, 2017 01:22 PM
brandon04
Oct 21, 2015 07:04 AM
ernnyyes
Oct 2, 2015 05:16 PM
jmelton327
Sep 26, 2015 10:04 PM
