RAW intake problems
Old Aug 14, 2008 | 01:28 AM
cobaltSS2.4liter's Avatar
RAW intake problems
So i just finished installing my new Rebal 3'' intake, and when i go oturn on the car it starts to sputter going from 1000 RPM to 300 then back up. WTF did i do WRONG!!! HELP PLEASE
Old Aug 14, 2008 | 01:30 AM
JRelly's Avatar
Did you disconnect the battery?
Old Aug 14, 2008 | 01:31 AM
ya i did that and it still did the same thing
you put it in gear and it stalls
Last edited by cobaltSS2.4liter; Aug 14, 2008 at 01:31 AM. Reason: Automerged Doublepost
KillerBee's Avatar
did you plug in your sensor and put the sensor in the right way?
JRelly's Avatar
MAF sensor in correctly?
Old Aug 14, 2008 | 01:32 AM
which way is the right way?
i thought there was only one way to put it in? the other way doesnt fit
Last edited by cobaltSS2.4liter; Aug 14, 2008 at 01:32 AM. Reason: Automerged Doublepost
Old Aug 14, 2008 | 01:34 AM
theneelster's Avatar
Check the maf and harness going to the maf. Did you disconnect any of the other connectors for clearance?
I still have to laugh when people have problems with installing an intake...I did mine with a broken back and a six pack in me and no issues!
Old Aug 14, 2008 | 01:46 AM
do you have the same intake? i only took off the headlight, thats it
anyone else have any thoughts? what if one of the rubber connectors was letting out air? could that be the cause of the problem?
Last edited by cobaltSS2.4liter; Aug 14, 2008 at 01:46 AM. Reason: Automerged Doublepost
Old Aug 14, 2008 | 01:49 AM
bshoe421's Avatar
its gotta be something with the maf...thats all i could think of
Old Aug 14, 2008 | 01:54 AM
RooTBeeR's Avatar
did u put the maf back in the right way?
..haha any one else?
my RAW CAI is fudgin sick!
Old Aug 14, 2008 | 02:13 AM
im going to switch it the other way around tomorrow. Im hoping that will fix everything
Old Aug 14, 2008 | 02:21 AM
bridfi's Avatar
there should be an arrow on the maf itself i know the 2.2s have an arrow
Old Aug 14, 2008 | 02:27 AM
WickedSS2005's Avatar
Did you upgrade to the LS4 throttle body without tuning it? Check all hoses in the engine bay and your CAI coupler clamps for loose connections cuz it sounds like a vacuum leak.
Old Aug 14, 2008 | 09:10 PM
Well...the maf is only going to fit in the pipe one way and the harness as well.
I don't think a vac leak would do that...I had the vac line COMPLETELY off my intake and didn't have any power problems except a sucking sound that wasn't there before.
Old Aug 14, 2008 | 09:28 PM
freakta's Avatar
did you get dirt on the maf at all. that could be some of it. i didnt have any problems with mine.
Old Aug 15, 2008 | 03:03 AM
Ramphex's Avatar
It's the MAF sensor man, make sure you have it in the right way else it'll do that and bog your car out if you try to drive it.
Old Aug 17, 2008 | 11:30 PM
So i figured it out thanks to all of you. it WAS the MAF sensor, had it upside down. But the thing is that the bolts would only fit it you put it in the wrong way. i mean is that normal? WTF Rebal
Old Aug 18, 2008 | 02:30 AM
RooTBeeR's Avatar
um, you might have that piece of intake pipe backwards then
Old Aug 19, 2008 | 02:46 AM
that makes a whole lot of sense. God all this could have been avoided if rebel gave me some damn instructions with the intake!!! thanks RooTBeeR. Ill change it when i get my new headlights in.
is the chripping noise normal, or is that the intake sucking up air? sounds like i have a turbo, makes that sound when i change gears sometimes
Last edited by cobaltSS2.4liter; Aug 19, 2008 at 02:46 AM. Reason: Automerged Doublepost
Old Aug 19, 2008 | 02:49 AM
MikeyB's Avatar
its not rebels fault you installed it incorectly lol. i had no trouble with my raw 3" and i used the how to's on here
its a sick intake
Old Aug 19, 2008 | 02:51 AM
hey man i never said i didnt like it, its sick im just a moron when it come to things like this lol.
Old Aug 19, 2008 | 09:29 PM
RooTBeeR's Avatar
Eh man, no prob...HIGH FIVE TO ME FOR FIGURING IT OUT!!! lol Glad I could help out. Yeah I had to use the RAW "how to" help hints for mine lol but its SICK for sure!
by "chirping" do you mean that noise that sounds like air getting sucked through a straw? cuz just off idle mine doses that. and cruising with the windows down it also has a kinda "sucking" noise.
Old Aug 24, 2008 | 11:25 PM
ok so that sucking noise is normal. I was worried something was wrong. Can I leave the pipe upside down? Will something go wrong down the road?
Old Aug 25, 2008 | 09:07 PM
Last edited by cobaltSS2.4liter; Aug 25, 2008 at 09:07 PM. Reason: Automerged Doublepost
Old Aug 26, 2008 | 12:59 AM
RooTBeeR's Avatar
what do u mean "upside down"? do u hav a pic?
