rear main seal install
Old Mar 30, 2015 | 11:32 PM
southal cobalt's Avatar
anybody have any information on replacing the rear main seal? ive already got the trans pulled. how do i get it off and what tool do i need to replace it?
Old Mar 30, 2015 | 11:38 PM
ItalianJoe1's Avatar
Seal puller to remove it, or a pick/screwdriver. Install with a soft drift and hammer.
Old Mar 30, 2015 | 11:39 PM
Omiotek's Avatar
^^^what he said
Old Mar 30, 2015 | 11:52 PM
okay, by soft drift, do you mean something like this,
Great deal on Mayhew Tools 61360 at TheToolWarehouse.Net
sorry for asking stupid questions, this is just something that i dont want to screw up.
another quick question. can i use lnf pressure plate bolts on the lsj upgrade kit? i stripped 3 of those torx heads pretty badly
Old Mar 31, 2015 | 07:48 AM
Yes that would be a soft drift
Old Mar 31, 2015 | 07:39 PM
Yeah a brass drift will be perfect, you can also use a little piece of aluminum if you have it available, i've done that in places. Just go slowly so you don't go to far on one side if you haven't done this before. It's better to spend 10 min and do it right than rush it and ruin the seal when you knock it in too far on one side first and distort it. Even depth is the key.
Yes you can use LNF bolts, they should be identical.
For balance reasons I like to use a matched set of whatever pressure plate bolts in question, having one of a different design can cause a light/heavy spot on the flywheel assembly.
Old Mar 31, 2015 | 11:02 PM
awesome thanks! yeah, i was gonna use all of the same bolts, i just wasnt sure if the thread was the same between bolts. the hex head looks like it will be nicer to deal with than the torx head.
patooyee
Oct 15, 2015 05:11 PM
justinchinn
Oct 2, 2015 12:18 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Delta coupe
Sep 30, 2015 08:11 AM
Trav3480
Sep 28, 2015 02:46 PM
