Rear o2 sensor
Rear o2 sensor
I'm throwing the heater core, blah blah code for the rear o2 again but cannot afford to fix it. Could this lean/richen anything or make my car run funny? Is this something I can drive with? I know guys delete them, but I don't know if they have to get a tune or something. I'm worried because I can't replace it right now but I need to drive my car.
Should be covered under the emission control equipment warranty - give the dealer a call.
Yup, just called them. ******** said it's not under warranty and would be 235 with labor. Theifs.
so will I have any issues without it for a while?
bump-worried guys
bump-worried guys
Should run not to bad as long as your not punching it .If you drive normal I dont think it will kill the car.
The car will run in closed loop but might be a little rich,meaning it could be bad for the cat.
Just found out the bosch o2's have a different heater core design and can trip CELs with our cars...****, looks like I'll have to drop 90 bucks on an acdelco
DANRICKARD
10-01-2015 12:08 AM
Delta coupe
09-30-2015 08:11 AM
