Rear o2 sensor
Old 01-27-2010, 01:04 PM
Jaemon52's Avatar
Rear o2 sensor
I'm throwing the heater core, blah blah code for the rear o2 again but cannot afford to fix it. Could this lean/richen anything or make my car run funny? Is this something I can drive with? I know guys delete them, but I don't know if they have to get a tune or something. I'm worried because I can't replace it right now but I need to drive my car.
Old 01-27-2010, 01:19 PM
DaBuzzard's Avatar
Should be covered under the emission control equipment warranty - give the dealer a call.
Old 01-27-2010, 02:30 PM
Jaemon52's Avatar
Yup, just called them. ******** said it's not under warranty and would be 235 with labor. Theifs.
so will I have any issues without it for a while?
bump-worried guys
Old 01-27-2010, 03:10 PM
Coblasts's Avatar
Should run not to bad as long as your not punching it .If you drive normal I dont think it will kill the car.
The car will run in closed loop but might be a little rich,meaning it could be bad for the cat.
Old 01-27-2010, 04:06 PM
Jaemon52's Avatar
Wait, so you're saying the rear o2 does more than just make sure the cats not killing the environment? It actually determines afr?? ****
Old 01-27-2010, 04:49 PM
Coblasts's Avatar
No but when a sensor is not working the car automatically goes into a closed loop.
It then runs on preset tables which generally tend to be on the rich side.
Old 01-28-2010, 02:50 AM
Jaemon52's Avatar
Just found out the bosch o2's have a different heater core design and can trip CELs with our cars...****, looks like I'll have to drop 90 bucks on an acdelco
Old 03-17-2010, 01:13 PM
recklessactn's Avatar
sorry to bring this back but yea I run the bosch replacement and it does throw one code p0054 :-( need to buy the oem rear 02 to fix
Old 05-10-2010, 08:14 PM
Omnigear's Avatar
so whats the actual manufactuer(sp) of the acdelco version?
so i dont hav ta pay an arm n a leg for an o2 sensor
my front is givin me the p0053 code
Old 05-10-2010, 08:51 PM
BlackJackSS's Avatar
if you still have a cat on your car and your throwing a code for the rear o2 sensor there is a good chance ur cat is getting clogged.
DarrenGC
12-24-2021 01:55 PM
Sl0wbaltSS
11-21-2018 11:11 PM
DANRICKARD
10-01-2015 12:08 AM
Delta coupe
09-30-2015 08:11 AM
jmelton327
09-26-2015 10:04 PM
Quick Reply: Rear o2 sensor
