Reasons for 4psi
Old Jan 20, 2018 | 02:55 PM
Builttss's Avatar
Reasons for 4psi
Hello community. Back after a couple years. Picked up a Stock 07 lsj with 60k. Only issue I have with it is that it will not boost over 4psi. Any common issues to replace? Boost acculator? The rod moves fine when I move by hand and vacuum lines seem to be good. Any suggestions? Thanks
Old Jan 20, 2018 | 03:41 PM
user 72239's Avatar
Any codes? When my LSJ did this I had a leak at the boost control solenoid
Old Jan 20, 2018 | 04:01 PM
Builttss's Avatar
no sir No codes. Where exactly where was you Leaking from?
Old Jan 21, 2018 | 11:29 AM
user 72239's Avatar
vacuum line was tore by the nipple on the BCS
Old Jan 23, 2018 | 08:29 AM
jdbaugh1's Avatar
Sounds to me like your bypass actuator solenoid is either faulty, unplugged or lost connection. It could also be your ECM telling the solenoid to pull boost but I would think it would throw a code? You can test if it is the solenoid by taking the hose that runs from the solenoid to your actuator, disconnecting it from the actuator while leaving it connected to the solenoid and plug it. If you can build boost after you have done that it is either your solenoid, solenoid wiring or the ECM telling it to pull power for some reason.
soyelbombero
Dec 14, 2009 07:23 PM
CLackey
Jan 26, 2005 08:15 PM
