Replace rear axle beam
Old Nov 20, 2010 | 10:28 PM
cmatthewb101's Avatar
Exclamation Replace rear axle beam
Has anyone replaced one? how hard is it?
Also the rear suspension support.
I have a 05 SS
Thanks in advance
Old Nov 20, 2010 | 10:30 PM
09sscalicobalt's Avatar
hmm i think will aka ls1fbody has he has the time attack one with the stock one in his garage
Old Nov 20, 2010 | 10:37 PM
j27-2's Avatar
I dont think it is very difficult at all just make sure you have a way to support all the wight without it flopping to one side
Old Nov 21, 2010 | 12:07 AM
Yea, that shouldn't be an issue. My and a friend were thinking about doing it. As long as it isn't anything else too fucked up with the car. gmpartsdirect wants 800$ just for the beam. Eff that. I can go to a junk yard and find one for like 150$
Old Nov 21, 2010 | 07:57 AM
Bump for info from someone that has done it
Old Nov 21, 2010 | 08:25 AM
twofknloud's Avatar
i switched my drum axle for a rotor axle, took less than 30 minutes
make sure to start with brake lines first, then remove shocks, springs
axle is held 2 long bolts, its very simple
i got mine from at local scrap yard, complete axle with calipers rotors and wheel bearing
all for $150
Old Nov 21, 2010 | 08:28 AM
Kyle4236's Avatar
all for $150
this. all it is the brakes and 2 bolts on both sides that need to come off. its unbelievably easy. i dropped mine down twice before just make sure you can support the car as mentioned earlier
Old Nov 21, 2010 | 08:33 AM
Ok sweet. It's at a dealership, it'll have a full inspection monday. I just know the beam needs replaced, but I don't know if anything else needs replaced. They're going to give my insurance a quote, and then me and a buddy are going to replace it ourselves.
biniecki
Oct 25, 2015 02:23 PM
justinchinn
Oct 2, 2015 12:18 PM
Trav3480
Oct 1, 2015 08:17 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Delta coupe
Sep 30, 2015 08:11 AM
