Replacing AC Line Help.
Old Mar 9, 2020 | 10:27 PM
blrt's Avatar
Just noticed after I got home that my ac line had a leak. This was from a braided ss line rubbing against it. The pic below is the one I need to replace. Is there anything I should know to make my life easier during the removal/install. After it is done, I will take it in the shop to charge/service the system. First time touching an AC system.
Old Mar 10, 2020 | 12:14 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
It's a fairly easy process, at least on my LSJ. I'd check on your car to see if there are many things looped over or around the line; scout it out and come up with a plan of attack. Might make it easier if you remove intercooler piping; I don't know though... haven't done an LNF.
With that said, you might be able to go to a shop beforehand and have them evac your system, that way you aren't having to deal with R-134a fumes and system remnants (it's kinda toxic stuff and will mess with your lungs)... but with there being a leak, that may not work.
Otherwise, you might want to wear a mask and/or run a fan nearby on high.
https://www.es-refrigerants.com/reso...%20hazards.pdf
Old Mar 11, 2020 | 08:47 AM
blrt's Avatar
It seems like all the pressure has been leaked/released as expected. No more sounds coming from the line. Just waiting for my new line and o-rings from RA to arrive. Then find a weekend to do this. Thanks for the reply.
bluelight
Dec 9, 2013 01:21 PM
redcobalt07
Aug 18, 2013 11:25 PM
SalvageBaltSS
Aug 11, 2013 03:06 PM
Macgyver2484
Oct 27, 2012 12:56 PM
startingline05
Jun 18, 2011 10:18 PM
