Resonating nose
Old Jun 23, 2022 | 08:39 AM
exninja's Avatar
Resonating noise
I've got a fun noise now! It used to make it pretty loud at 2000rpm, but it's quieted a little at that speed. Instead, it's growling at 3500-4k. The longer it sits there, the worse it sounds. It seems to happen about 3.5k when accelerating, and 4k when decelerating (but that could be perception or delay in the tach). Anyone seen this before? Next would be to get my wife to work the throttle to see if I can find where it's coming from. It does seem to vibrate in the car. It happens whether or not the clutch is in, so I don't think it's the trans. There's a video:
https://youtu.be/-cuncDVXncQ
Old Jun 23, 2022 | 09:14 AM
exninja's Avatar
I just noticed the title says nose instead of noise. Lol @swype
Some more info I just thought of. I just repaired my fuel pump and the noise began immediately after that. I figured it was coincidence, or something I didn't notice before because I didn't think there was anything that I would've done to make a noise like that. Then I remembered i had to mess with the exhaust to drop the tank. I'll check out the hangers and mess with it to see if that's the source. Any other ideas?
Old Jun 23, 2022 | 09:19 AM
I was going to comment on the title
I would suggest going over everything you removed & re-installed during the fuel pump replacement and hopefully, it's not the fuel pump itself.
Old Jun 23, 2022 | 10:03 AM
exninja's Avatar
Yeah, I'll get down there tonight. I don't know how it could be the pump, but strange things happen. Hopefully it's a bound or broken hanger, or maybe loose heat shield.
Old Jun 23, 2022 | 09:36 PM
exninja's Avatar
Found it! The tank had deflected some heat shield down which was vibrating on the exhaust. No more noise!
Sam Faulhaber
Sep 7, 2020 06:26 PM
genosis8703
Jul 17, 2018 09:58 PM
Dylan_09ss
Sep 12, 2017 02:17 PM
Twoozofjuice
Jul 16, 2012 06:21 PM
Toyotech
Oct 25, 2007 10:10 PM
