Reverse gear slipping / not engaging
Old Aug 10, 2015 | 11:46 PM
Trav3480's Avatar
on occasion, not 100% of the time when i engage reverse , it will either slip and i can hear the flywheel / clutch plate kinda drag, or it will grind into reverse almost like i never pushed on clutch at all. again this doesnt happen every time and only fix i have found so far is put it in 1st, inch up then go back into reverse... any ideas?
Old Aug 11, 2015 | 03:27 AM
Sl0wbaltSS's Avatar
Well, seeing as you'll never miss reverse like you do 3rd I'd say your cables are stretched, or need adjusting.
Old Aug 11, 2015 | 06:17 AM
Wow actual good advice
Old Aug 11, 2015 | 08:21 PM
kzak104's Avatar
if you just jacm the clutch in and throw it in reverse it will grind because the tranny is still spinning and reverse isnt syncrod, i usually put it in 3rd then reverse, sometime it wont go into reverse so i let the car roll a bit then it slides in
shitty tranny is shitty
Old Aug 12, 2015 | 01:54 AM
Reverse is syncronized.
Old Aug 12, 2015 | 06:29 AM
insylem's Avatar
I don't think it is.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
