Right....so to the dealer I go
Old Nov 5, 2007 | 09:37 PM
CCBalla10's Avatar
well guys my LT has been great and still is, cept for now I have to take it to the dealer b/c as of tonight I have the key getting stuck in ignition and water leaking from the sunroof button....grrr...do you think they will do the warranty work if I have the airbox mod? :S
Old Nov 5, 2007 | 09:39 PM
Sunburst_SS's Avatar
I assume you have an automatic??? The key getting stuck is the solenoid on the shifter assembly on the floor....they should warranty it. There i actually a release button on the bottom of the steering column to release the key.
Old Nov 5, 2007 | 09:42 PM
Red2.4SS's Avatar
Yeah, they'll fix it as long as it is still under warranty
CCBalla10's Avatar
well do you think they'll do it when they pop the hood and notice that its been modded?
Old Nov 5, 2007 | 09:43 PM
hinow41's Avatar
what mod do you have to the air box?
Old Nov 5, 2007 | 09:48 PM
Beck's Avatar
one item that voids the warrenty does not void the entire warrenty, it only voids it for that part. They're not going to deny your leaky sunroof button because you have an airbox mod lol, it doesnt work like that. Unless there is someway your airbox mod made your sunroof botton leak (lol) then no, they wont care.
DebadgedBALT77's Avatar
an airbox mod, has nothing to do with a leaking sunroof or the key. they will cover it. I know we do. It will still be under warrenty. I know at work the only thing we havent touhed was a Z28 that was, cammed, tuned, motorswapped, headers, etc. They had a rough idle an we all refused to work on it. So i think your alrgiht then man! good luck
Old Nov 5, 2007 | 09:50 PM
CCBalla10's Avatar
the airbox mod...for the 2.2L
alright cool...this is the 1st car i've bought that is new, so i didn't know exactly how modding and warranties worked...thanks for the info guys!
Old Nov 5, 2007 | 09:54 PM
Red2.4SS's Avatar
The air box has noting to do with the problems you are having so it will not be a problem. I had stuff fixed on mine and I had way more mods.
Old Nov 5, 2007 | 10:01 PM
Greased's Avatar
im not sure why you would go back to the dealer with all that stuff in your car... like realistically its less stock than modded you know more about your car at that point then the dealer does
Old Nov 5, 2007 | 10:40 PM
yea, kinda had us puzzeled too, they had another problem then wanted us to fix that. It was kinda obvious that the problem was, no o2 sensor, along with horrible hirrible timing issues. but, somethings are best left alone.
Old Nov 5, 2007 | 11:34 PM
Sharkey's Avatar
you should have no probelm with that. if they give you any flak for it, ask them how the airbox mod made your key get stuck and sunroof button leak. if they give you some bs reason, just argue till they fix it.
it will depends on the stealership. just before i bought it, my car had a wheel hub replaced under warrenty, despite the fact its lowered, 2.85" pulley, cobra heat exchanger, 3" exaust with electric cutout, and traction bars. basicly comes down to the dealerships standing with the warrenty reps.
Old Nov 6, 2007 | 11:13 AM
kenhebe's Avatar
Your airbox has absolutely nothing to do with the problems you are having.
Old Nov 6, 2007 | 03:01 PM
CCBalla10's Avatar
thanks already been covered
ricklovin93
Aug 27, 2016 06:35 PM
agentirons
Oct 16, 2015 02:11 AM
bigdogstokes16
Oct 8, 2015 10:28 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
