roll pin was missing trans locked in first
Old Aug 28, 2012 | 04:09 PM
wRcKLes's Avatar
I was driving home and at the top of the hill to my street when the car im assuming lost its roll pin while i was in first gear ( i found this out by pulling the car apart today that the roll pin was missing) i pushed in the clutch and coasted the car into my driveway but now its locked in first gear
I can move the main shift linkage with the counter weight ontop of it back and forth no problem its the other smaller peice next to it I cant move at all
Im currently in the process of re installing the main roll pin but i still have no idea how im going to move the thing after if the trans is locked in first
any and all help is thanked greatly
Old Aug 28, 2012 | 04:23 PM
wRcKLes's Avatar
so like i stated I can move the shifter back and forth in between first and second but I can not move it over left and right ...... so 3rd 4th 5th and reverse is locked out
Old Aug 28, 2012 | 08:51 PM
wRcKLes's Avatar
seems as if no one else knew the answer either
well i found out the when the roll pin fell out, it was a universal roll pin i dont suggest you use one...ever but when it fell out the car was still in first gear so the trans was locked in first once the new roll pin was installed everything went back to normal
dennis69
Oct 20, 2015 07:39 AM
HEATON
Oct 16, 2015 07:21 PM
agentirons
Oct 16, 2015 02:11 AM
Trav3480
Sep 28, 2015 02:46 PM
