running lean
Old Jan 24, 2009 | 12:39 AM
ikeryder13's Avatar
running lean
I am getting code p0171, or i am running lean....
These are my mods
GMPP Stage 2 Performance Kit
TTR Motor Mount
Vibrant Header/Downpipe Combo
Hahn 3” Catback Exhaust
ZZP Heat Exchanger
R.A.W. Cold Air Intake
GMPP Option B Tank Kit
Spec Stage 2+ Clutch
Aamco Lightweight Flywheel
i am planning on switching to a 2.9 pully... but leaving the gm tune, will this help at all?
Old Jan 24, 2009 | 12:42 AM
D4u2s0t's Avatar
no, it won't help at all. smaller pulleys and leaving everything else stock will make you run more lean. make sure everthing is tight around your intake. all the connectors, filter, etc. it's very common to get that code with an intake on the car, almost everyone will get it at some point. if you're very concerned you can get a wideband.
Old Jan 24, 2009 | 12:43 AM
ikeryder13's Avatar
i am a lil... i figured its from my hahn catback..
Old Jan 24, 2009 | 12:53 AM
D4u2s0t's Avatar
it's not from the catback... p0171 is from the maf. long story short the maf is reading more air than it's supposed to. if you delete the code it may not come back.
Old Jan 24, 2009 | 12:55 AM
ikeryder13's Avatar
oh ok
Old Jan 24, 2009 | 01:14 AM
D4u2s0t's Avatar
very common with aftermarket intakes. like i said, almost everyone will get that code at one point or another. when i had my 2.2 took over a year to get the code. deleted it, never came back. on my 2.0, i got it pretty quick. deleted it, never came back.
Old Jan 24, 2009 | 01:19 AM
ikeryder13's Avatar
yeah i have had the intake and it never came up till now
Old Jan 24, 2009 | 01:46 AM
Sharkey's Avatar
thats not actualy correct. the maf reads the air going in and the pcm calculates the required fuel for that airflow. the o2 sensor then picks up the oxygen in the exhaust stream, and if it shows the engine is running lean it will try to correct it in the short term fuel trims, and will eventualy cause a lean code (p0171).
now the reason cars with aftermarket intakes tend to set this code is because the piping is now larger and not 100% of the incomming air is getting metered. basicly the maf doesnt read all the air comming in so the pcm doesnt supply enough fuel for the correct mixture.
Old Jan 24, 2009 | 02:34 AM
ikeryder13's Avatar
so what should do?
Old Jan 24, 2009 | 02:46 AM
Sharkey's Avatar
i would clear the code and see if it comes back, if it does, the only real way to get rid of it is to remove the aftermarket intake.
Old Jan 24, 2009 | 02:59 AM
ikeryder13's Avatar
oh ok... will it make my car run bad?
Old Jan 24, 2009 | 03:08 AM
Sharkey's Avatar
if your car running bad now???
Old Jan 24, 2009 | 03:09 AM
ikeryder13's Avatar
no its not really
Old Jan 24, 2009 | 08:09 AM
Coblasts's Avatar
How long have you been running with the mods and the cai before the code came on?
Ive had my injen on for over a year with the stage 2 and never had the code come up.
You can make sure that you have all the updates to the stage 2 flash ,there was a tsb on the p0171 and a reflash that was for it I think.
Someone might be able tp verify that for me.
Read the sticky at the top of the section.
Old Jan 24, 2009 | 11:48 AM
TRANSAM197781's Avatar
check all youre intake connections maake sure there seated properly and tight I also rotated my filter and retightened it and that fixed my code
Old Jan 24, 2009 | 01:54 PM
ikeryder13's Avatar
yeah it wasnt until i had my clutch redone that it came up
turbochargedss2012
Sep 20, 2023 12:17 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
tomj77
Oct 4, 2015 11:39 AM
dieGone
Oct 1, 2015 06:27 PM
DocSvensk
Sep 27, 2015 02:24 PM
