Service ESC after lowering
Old May 8, 2014 | 02:51 PM
09Balt.SS's Avatar
So I did a bit of research on this forum and others but have not found a clear answer yet.
The situation is: I lowered the car on SSC lowering springs just before busting it out of winter storage. Ever since, I am getting a "Service ESC" DIC message every single ignition cycle.
I have not yet got an alignment but will in the next few days. It definitely needs one after lowering as my steering wheel is angled >30 deg when going straight.
I suspect that the Stability Control system is taking in the steering angle data (which is wrong obviously) and throwing the msg, but I am hoping someone else can confirm that the alignment should fix this issue?
Will I also need to recalibrate the steering angle sensor after alignment or should I be good to go after alignment?
And finally, I don't think I messed anything like the ABS up when lowering, but could that also be a factor??
Old May 8, 2014 | 03:28 PM
hawkssoccer11's Avatar
are you just getting the service esc light or abs and traction control as well??
Old May 8, 2014 | 06:13 PM
sLAsh's Avatar
Did you unplug the wheel speed sensors to do your springs?
Old May 8, 2014 | 08:39 PM
Piston3's Avatar
This. Check the plugs. I got excited and left one out. Light was off by the time I got out of the driveway.
Old May 8, 2014 | 09:09 PM
That's why I asked if your other lights were on side I did the same thing haha
Old May 8, 2014 | 10:25 PM
ItalianJoe1's Avatar
Yeah it sounds like you may have left a wheel speed sensor off or possibly damaged one or the harness going to it. Start there.
Old May 8, 2014 | 10:47 PM
09Balt.SS's Avatar
hmmm, I'll look into the wheel speed sensors. I didn't purposely unplug or mess with any of the wheel speed sensors, not even sure where they would be (guessing by the abs mount?)...
It only says "Service ESC" then "ESC off" and the traction control icon lights up. No ABS lights or undesired ABS events.
Old May 8, 2014 | 10:50 PM
The sensors are part of the wheel hubs, the wires run up along the brake lines to the body and back into the harness. Hopefully you just unplugged one, if not you might need to pull the error codes and see what fault it's indicating, that will point you in the right direction and to the right corner.
Old May 8, 2014 | 10:57 PM
09Balt.SS's Avatar
Per handheld device, no stored/pending/current error codes. No DTC/CEL.
Old May 8, 2014 | 11:01 PM
Yeah a basic handheld won't see it, it won't pull the BCM errors for ABS/ESC. I have a simple one that doesn't see them, if I use the big scanner at work it will show a wheel speed signal circuit failure or something.
Old Jun 5, 2014 | 01:32 PM
09Balt.SS's Avatar
Followup:
ESC issue went away after the alignment. I guess lowering through off the SAS or soemthing. Thanks for all your help!
dennis69
Oct 20, 2015 04:49 PM
patooyee
Oct 15, 2015 05:11 PM
importkiller
Sep 30, 2015 07:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
