severe sludge need help
Old Mar 20, 2011 | 09:30 PM
hersh81211's Avatar
so i changed my timuing chain tensioner the other day i pulled my valve cover and my motor is nothin but skludge car has 48k ive only owned it for 10k but ive never missed an oil change. its ao bad as that my oil ports are clogged and the top of my motor isnt gettin much if any oil any advice on how to clean it out without havin to dissasemle the motor or get a new one. ive seen alot about seaoam but im worried that is gonna let some big chunks loose and clog the oil pumo screen and seeze my motor. Any suggestions or ideas would be appreciated
Old Mar 20, 2011 | 09:41 PM
lsjion's Avatar
hope it's not peanut butter looking.
However, be careful flushing it out, doing a simple oil change with synthetic can be bad, if all that stuff breaks up, it could cause damage.
Old Mar 20, 2011 | 09:43 PM
DiabeticKripple's Avatar
i would spray as much as you can off, then seafoam it
Old Mar 20, 2011 | 09:49 PM
noblite's Avatar
One thing you want to look out for is that the oil filter doesn't get plugged up and cause damage from oil starvation. I'd go to walmart and get some cheap super tech filters and chage it out about half way through the oil change.
Old Mar 21, 2011 | 08:27 PM
lsjion's Avatar
I'm pretty sure the oil filter can be bypassed when it is clogged like most engines
Old Mar 22, 2011 | 08:28 PM
rukkee's Avatar
If the engine is sludged up that bad it sounds like the prior owner never changed his oil or something . I've heard a quart of diesel or kerosene can be used to flush an engine .... or im sure there is something at the parts store thats made to do it like seafoam . I use seafoam every oil change threw the intake because of Direct Injection / dirty valve issue . I haven't used it in the oil so i cant comment .
Any pic's of the sludge?
Old Mar 23, 2011 | 05:48 PM
noblite's Avatar
It will go into bypass mode but that will allow anything in the oil to go right to the engine unfiltered. The filters are 2.87 plus tax at walmart and they are as good as the ac delco filters you get from the dealer.
Old Apr 1, 2011 | 03:47 AM
xdjstylz330x's Avatar
If u want a good way,may soynd strange but run 4qt kerosene and 1 qt oil. Change filter prier. Start car but do not rev...i repeat..DO NOT REV. Leter sit at idle a few. Change oil but when u drain, pour kero untill **** stops coming out nasty like. Run 2 qt oil in with plug then drain again, but dont start it. Then change to oil u like normally. Drive 50 miles or so to circulate new oil and grab all that excess kero. Then...change again. This time you should be good. So thats 3 new filters and almost 3 sets of oil.
If your weary of doing this, check out the stuff shops use to flush and compare....same stuff almost lol..
I did this to all my cars before. If anyone has a diff way that works as good...kool.
Old Apr 1, 2011 | 08:59 AM
reddevil's Avatar
We need pics to see what type of sludge you are talking about.
Old Apr 1, 2011 | 09:15 AM
jlong3382's Avatar
Change your oil. Add a quart of transmission fluid to 4 quarts of engine oil. That's always worked for my cars in the past
Old Apr 3, 2011 | 05:04 PM
ronn's Avatar
USE Pennzoil ULTRA 5/30 and run for 2k Miles..then do that two more times. Stay with it for 5K after that. This new oil WILL REMOVE SLUDGE slowly. Don't sea foam it.
So clean is it that, in addition to helping prevent the buildup of sludge and other deposits in the engine, the oil also cleans up existing sludge when used in an engine that had been running on a different oil. All the while, Pennzoil Ultra provides better wear protection than any other leading synthetic motor oil, according to Shell.
Shell
Old Apr 3, 2011 | 05:15 PM
gotboost?17's Avatar
Nothin Stock
in for results
Old Apr 3, 2011 | 06:12 PM
olivecj's Avatar
totally agree on using penzoil, i haven't changed my oil for about 5 months and i checked it today and its golden brown. I am gunna change it out though at the end of this month, but it just goes to show ya how good that oil is . So for the "op" I would not use the seafoam and try penzoil platinum or ultra and slowly get the sludge out that way.
Old Apr 3, 2011 | 06:16 PM
68nova200's Avatar
I disagree. I used the cheap ones for a while and after 3000 miles the filter material became distorted/ bend. i switched to the acdelco and have had no problems after 4000 miles.
Old Apr 3, 2011 | 07:35 PM
rnjmur's Avatar
If the sludge is that bad you are going to have little choice but to use kerosene or seafoam to clean it out.
The real question is WHY is there sludge? If the oil was changed with the proper synthetic oil then the only answer would be contamination, probably from coolant. Of course you have no idea what type of oil was used in the car before you purchased it so it is hard to know for sure if that was the contributing factor or not. Also, what oil are you using for oil changes?
Old Apr 3, 2011 | 09:08 PM
C_A_D88's Avatar
pics?
Old Apr 4, 2011 | 09:35 AM
stonny9's Avatar
Please post pics as requested before. Also do a google search on how to flush an engine. I you are that concerned about oil pump blockage then install an oil pressure guage.
Old Apr 5, 2011 | 12:42 AM
hersh81211's Avatar
thanks alot for all the responses sorry for takin so long to get back to on. i forgot to take pics before i but cover back on been busy past couple weeks so havent even had a chance to get back in ther yet hopin to this week and will post them when i do. the only thing i can think for a cause is the girl who had it before me didnt doi any oil changes, she told me they ran full syntetic so i did regular oil changes with mobile 1 full synt. i was goin to try to get as much sludge out of the valve covers and oil pan by hand before i seafoam it and clean it out again after seafoam and then do short interval oil changes.
Old Apr 5, 2011 | 12:50 AM
CanadianCobalt's Avatar
Fwiw, I used to have an Isuzu Rodeo that had inherent problems with sludge building up on the rings.
Anyways long story short, the rule of them to get rid of crap in the engine with them was to use Shell Rotella diesel oil (It also meets standards for gasoline engine oils) as it had a bunch of detergents in it to break it down and it worked spectacular. It may be worth a shot.
Joel
Hugger1975
Oct 15, 2015 03:28 PM
Oct 13, 2015 09:32 PM
speedlimit
Site Development and Help
Sep 25, 2015 08:04 AM
