slight jerk while in boost
Hey guys i have a 07 SS. Car jerks sometimes while in boost and boost will fluctuate for example from 6 psi to 1 and back up . Especially when i first start the car and start driving aftr it warms up. Usually after i drive it for a bit the jerking will go away when i hit boost. I have no check engine lights for this. Did some reading saw it could be throttle body. What do yall think?
Well if those two codes came up there is an obvious problem some place. You might have to check the pedal to make sure it is working correctly. From the sounds of it as well, it could be the computer being faulty but I would rather check the pedal for the resistance to make sure it's working correctly before jumping to conclusions.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
