Some Problems...
Old Nov 6, 2007 | 10:44 PM
BlackSSNick's Avatar
Some Problems...
So I have an 07 cobalt SS/SC and it has heated front seats on driver and passenger side. Well the passenger side still works according to friends sitting in the passenger seat, but my driver seat doesn't work anymore. It worked fine for about a month and then it just decided to stop working. When I flip on the switch the light turns on meaning it's activated, but no heat. Also tonight my sunroof started acting up. I used to be able to only push the button half-way so the sun roof would open but not start going back. Well now that doesn;t work, I have to push the button fully in order for the sun roof to open and it even opens slower. Maybe a problem with the motor? Or electrical system? Thoughts and suggestions would be a great help!
Old Nov 6, 2007 | 10:47 PM
lijewski's Avatar
bring it in to the dealer. thats why you have a warranty.
Old Nov 6, 2007 | 10:52 PM
I realize this, but just was curious if anyone else had similar problems
Old Nov 6, 2007 | 11:16 PM
deuce's Avatar
my car is an 07 and it squeaks, sunroof rattles
Old Dec 6, 2007 | 08:02 PM
stlurbanpunk's Avatar
i'm having problems with my sun roof two, but its just the button trim that keeps falling off and the button is not secured to the posts anymore. I took it to the dealer to get it fixed once before and surprize it fell off again. i just want to replace that cheezy button with one that feels better and has one touch.
anybody have any suggestions?
Old Jan 14, 2010 | 07:52 PM
2.4SlowassBalt's Avatar
bump, im having these same issues and i have no warranty.... im having both problems btw although the heated seats are what i really want fixed.
Old Jan 15, 2010 | 09:57 AM
Old Jan 15, 2010 | 04:12 PM
Coblasts's Avatar
Starting here:
1) Did you check the fuse under the hood labled "HTD SEATS" 15 amp.
Question :Both seat heaters dont work.
Old Jan 27, 2010 | 01:40 PM
ricetimo's Avatar
Yeah, I'm having the same issue with the sunroof button. I have an 07 SS/SC and just passed the warranty deadline. The sunroof button bracket has fallen down a bunch of times and the mount (where the button sits) has become loose or something.
Is this something that can easily be fixed, like I could do myself or do I HAVE to take it into the dealer to get charged up the a$$????
Please advise.
Thanks in advance!
Old Feb 2, 2010 | 08:48 PM
girl loves cars's Avatar
i have heated seats and the driver's seat takes much longer to heat up than the passenger's seat. has anyone else had this problem?
Old Feb 4, 2010 | 07:37 PM
ricetimo's Avatar
Ok so I've check other threads and everyone keeps saying that there is a great "how to" write up on the solution to this (the sunroof button issue) but I can't find it.
Can someone please direct me to the link/thread????
Please!
Old Feb 7, 2010 | 11:53 AM
blitzed~beretta's Avatar
find your heated seat connector under the seat. should be a smaller plug with two wires that runs under the fabric near the center console. unplug it, throw a test light between the two terminals in the "body side" of the connector. turn on your heated seat. your looking for your test light to light up, showing you have good power and ground to the heating element. if you do, buy a new element, rip your seat out, take it apart and change it. it will probably be melted and burnt on the wires just before the element panel. if you don't have power or ground (test light does not illuminate) you have other problems like a fuse or wiring, switch, etc. I believe both seats run off the same fuse, so that is unlikely if one works though.
Old Feb 8, 2010 | 09:51 PM
thanks for the advice! i'll be looking into that when i get a chance
low_k3y
Jun 13, 2015 01:37 PM
riceburner
Aug 5, 2013 09:55 PM
xxBeaudsxx
Oct 14, 2012 12:03 PM
USMCFieldMP
May 6, 2011 05:30 PM
