The squeak of annoyance.
Well I have tried searching and all but I really could not pin point their relevance. Here is my problem.
My passenger front wheel (I believe) makes a high pitch squeak. It sounds like for every rotation of the tire it makes a squeak note. I hear it when I'm in a residential area (30 mph) and the sounds bounces off various objects thus bounces into my hearing. This sound is really irritating and can be heard past my radio with its annoying high pitch. Any clue on what this may be?
--Alex
--Alex
Rotor may have a slight run out and your brake pad could be rubbing on it or the wear indiator on the pads.If its the wear indictor touching just bend it slightly away from the pad.
Check out the pads for wear and let me know.
mine was doing the same thing from what it sounds like ur describing. it ended up being the clips on the brake pads that hold it into the caliper were rubbing the rotor. thats how low my pads were :/ but yeah, it was comin from the passenger side, and horrible at around 30 mph, then went away at higher speeds. then continues when i slowed back down. check on those tho.
--Alex
--Alex
YellowG5
Jul 5, 2007 02:25 PM
