squeeky wheel, wtf
squeeky wheel, wtf
over the past maybe 2 weeks or so my front driver side wheel has been squeeky.
anyone have this before? i'm going to try to look at it in the morning, if i have time before work. \\
WHat i have to work with:
it does it at all speeds, doesn't matter if i'm in gear or not, only when going straight, doesn't do it when turning.
any ideas?
any ideas?
Brake pads I had 18,000 miles and my car did the same thing and the squeek will get worse there is a small metal plate that rubs on the disc telling you to replace the pads before you have to replace the disc. get the brake pads checked or pull the tire off and look for yourself. I let mine squeek for one day and that was enough
haha, yea it is actually, but steady, not random!
no idea. i was looking for ideas before i check
i'm not sure what it could be. it's definitely coming from the front right wheel though. you can only hear it with the window open, it's not that loud. with the window closed you can't hear it at all.
DANRICKARD
Oct 1, 2015 12:08 AM
