squeeky wheel, wtf
Old Nov 19, 2007 | 09:59 PM
D4u2s0t's Avatar
squeeky wheel, wtf
over the past maybe 2 weeks or so my front driver side wheel has been squeeky. anyone have this before? i'm going to try to look at it in the morning, if i have time before work. \\
WHat i have to work with:
it does it at all speeds, doesn't matter if i'm in gear or not, only when going straight, doesn't do it when turning.
any ideas?
Old Nov 19, 2007 | 10:00 PM
SS_Ry's Avatar
brake pads?
Old Nov 19, 2007 | 10:01 PM
D4u2s0t's Avatar
Originally Posted by SS_Ry
brake pads?
could be. not sure. it's not a constant sqeek. it seems like it does it at a certain point in the rotaion of the wheel if that makes sense. it's not sqqqquuuuuuuueeeeeeeekkkkk it's squeak squeak squeak sqeak
Old Nov 19, 2007 | 10:02 PM
Qbyak68's Avatar
hey man...my car is doin the same thing...its weird
Old Nov 19, 2007 | 10:09 PM
D4u2s0t's Avatar
guess i'm not alone
Old Nov 19, 2007 | 10:17 PM
shortyheldberg's Avatar
Brake pads I had 18,000 miles and my car did the same thing and the squeek will get worse there is a small metal plate that rubs on the disc telling you to replace the pads before you have to replace the disc. get the brake pads checked or pull the tire off and look for yourself. I let mine squeek for one day and that was enough
brake pads?
Old Nov 19, 2007 | 11:03 PM
D4u2s0t's Avatar
so the consensus seems to be brakes. i had a feeling. i'm at 22,000 miles so sounds about time.
Old Nov 19, 2007 | 11:05 PM
CobaltVenomSS's Avatar
so its like listening to a basketball game??? lol
Old Nov 19, 2007 | 11:09 PM
stealthy1ss's Avatar
Could it be a wheel bearing?
Old Nov 19, 2007 | 11:31 PM
D4u2s0t's Avatar
haha, yea it is actually, but steady, not random!
no idea. i was looking for ideas before i check i'm not sure what it could be. it's definitely coming from the front right wheel though. you can only hear it with the window open, it's not that loud. with the window closed you can't hear it at all.
Old Nov 19, 2007 | 11:32 PM
madmark's Avatar
i would say your rotors need to be resurfaced and check the pads. if your driving on the hwy and you hit your brakes does your steering wheel shake?
Old Nov 19, 2007 | 11:39 PM
D4u2s0t's Avatar
not at all. i rarely even use the brakes. i downshift and coast to a stop more than i use the brakes hands down.
Old Nov 19, 2007 | 11:40 PM
i downshift and use the brakes
Old Nov 19, 2007 | 11:42 PM
D4u2s0t's Avatar
well reading through one of my car maintenance books it looks like it is the brakes. sounds like the exact symptoms i'm seeing. guess i'll check them out and see how they look.
madmark's Avatar
my guess would either be
a. rotor and brakes comming in contact
b. faulty wheel hub
Old Nov 20, 2007 | 05:01 PM
D4u2s0t's Avatar
i ordered new pads from ttr today. let's see if that takes care of it.
Old Nov 20, 2007 | 06:51 PM
afireinside7710's Avatar
my problem is the wheel squeaks and stuff when i go over bumps..
Old Nov 20, 2007 | 08:33 PM
Coblasts's Avatar
You could bend the little tab away for now until you have time to change the Pads.
That way you dont have to listen to the squeaking!
Old Nov 20, 2007 | 10:52 PM
madmark's Avatar
check your hubcaps to see if they are tight and drive close to the sidewall on the hwy and see if you can hear a constant squeek, tsb for that
Solaris99
28
Mar 15, 2017 01:22 PM
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
DANRICKARD
Oct 1, 2015 12:08 AM
