Stage 2
Old Aug 9, 2008 | 10:26 PM
tblanc's Avatar
Exclamation Stage 2
Hey I just had GM put in a stage two in my 06 Cobalt ss/sc and there is a noise comin from the engine kinda like a tickin noise. Im using 91 oct. at the pumps, does anyone know what it could be???
Old Aug 10, 2008 | 01:53 AM
theneelster's Avatar
It's better if you can find 93...you'll get knock below that.
Old Aug 10, 2008 | 01:54 AM
J.CobaltLT's Avatar
^ true.
i want gm stage 2
Old Aug 10, 2008 | 01:58 AM
ls1fbody's Avatar
Haz l33t wheelz.
cali doesn't have any higher than 91. it sucks.
Old Aug 10, 2008 | 02:08 AM
thought's Avatar
You can probably find some 93 or 94 if you look hard - if not, you may have to use octane booster. The other option that would be more permanent for you would be water injection (doesn't have to be meth). Or you could go further and do dual-pass, H/E, and meth or water injection. Those will lower your air temps and should eliminate knocking even at 91 octane.
Old Aug 10, 2008 | 02:27 AM
Kibosh3's Avatar
im gonna go on a whim and say that your hearing your new injectors...
Old Aug 10, 2008 | 09:26 AM
Coblasts's Avatar
I concur
If its coming from the belt side
SC bearing could of been damaged changing the pulley !
Belt tensioner
Old Aug 10, 2008 | 08:48 PM
Belt tensioner
One would hope that GM dealers could install their own parts correctly, but one would be disappointed when many can't.
Old Aug 10, 2008 | 09:24 PM
dantheman07ss's Avatar
take it back up there. but more than likely i would say it is the injectors. stock ones are loud enough on these cars, let alone the 42.5'ers
Old Aug 10, 2008 | 10:53 PM
rukkee's Avatar
Could be the injectors or the timing chain tensioner . Does it do it all the time or only on a cold start?
Old Aug 13, 2008 | 04:26 AM
along440's Avatar
X2 need to know too..my car sounds horrible all i run is 93 and it does it all the time...only mods are highflow cat gm stage 2 and a injen cai
Old Aug 14, 2008 | 07:30 PM
ssscs10's Avatar
when i picked up my car it was making a wierd ass noise too.. i left it running and called the manager over and he was like can i help you? i told him to listen and he said damn that sounds like ass. i said yea it wasnt making that noise when i brought it to you. so he had the head installer take it to the back and he routed some hose wrong that was supposed to be routed another way. it was rubbing on the transmission or somethng he said, but i think he was full of ****. i stayed for an hour after they had my car for 2 weeks, bitching them out.
Old Aug 14, 2008 | 07:45 PM
06stage2's Avatar
i got a gm stage 2 and i just had it stage 2 put in an i run 91 an my car has alwase had a ticking nose even sence i bought it brand new 93 dident make it run n e better i found that mine dose not misfire as bad on 91 tho
DarrenGC
Dec 24, 2021 01:55 PM
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
grampss
Sep 27, 2015 08:51 PM
