Stage code
Old Mar 19, 2009 | 08:12 PM
94firebird's Avatar
Stage code
i have the stage 2 installed.... some problems have gone ary and the dealership says they need to reflash with my code...... well i have either misplaced or never got back my stock parts so i was wondering what can i do about it.
i got my stage 2 from crateenginedepot.com so you know
Old Mar 19, 2009 | 08:24 PM
5hizn1t's Avatar
If the dealer that originally installed your stage 2 done it correctly, you will not need the code. All they will have to do is do a normal reflash of your PCM and GM will automatically give the dealership the correct flash. The flash is changed at GM's side to automatically give the correct flash no matter what dealership you go to. They bind it to your VIN. The tech calls GM and gives the auth number on the instruction sheet. After that, GM changes the programming that is assigned to your VIN. From then on, your VIN will have the stage 2 flash.
Old Mar 19, 2009 | 08:31 PM
94firebird's Avatar
so are you saying they can look up my reflash code by merly looking up my VIN number?
Old Mar 19, 2009 | 10:07 PM
Erod's Avatar
Moderator Alumni
moved to correct forum
Old Mar 19, 2009 | 10:11 PM
boostedss26's Avatar
The vci number is vin spacific they should be able to find it
turbochargedss2012
Sep 20, 2023 12:17 PM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
