steering getting stuck
Old Apr 17, 2014 | 11:35 PM
Sachemhockey44's Avatar
Hey guys, lately I've noticed that if i try to turn my wheel while my car is stationary it is very tough to do and feels stuck. This is especially annoying during 3 point turns. What could this be, the steering seems normal while driving its just when I'm still it is very tough to turn the wheel. Thanks guys.
Old Apr 18, 2014 | 06:59 PM
bump, anyone have the solution?
Old Apr 18, 2014 | 07:23 PM
soaxin's Avatar
Check your electric assist pump. Also make sure your rack isnt leaking. Had the same issue on my ION. Turns out the rack leaked out all the fluid.
Old Apr 18, 2014 | 08:12 PM
Nightwalkerhemi's Avatar
Check low fluid first if your low there's a reason,find the reason find your problem.
I had two power steering problems two different cars same day,maybe due to cold weather,I don't know.i still have oil stains all over driveway from the two cars.
One was a steering hoes,other was rack
Old Apr 18, 2014 | 08:13 PM
ItalianJoe1's Avatar
There's no fluid in the rack. The assist motor is all electric, looks like a starter motor attached under the steering wheel inside the car. From your description it's failed. I'd get a quote on replacing it.
Old Apr 18, 2014 | 10:00 PM
hmmm... i had something with the power steering replaced under recall a few years ago i wonder if that is the part that has failed. Is there a way to diagnose if its definetly the assist motor that has failed before buying a new one and replacing it? Are these expensive?
i havent noticed any leaks although im not sure where i would look to see if that is the problem. I havent noticed any stains underneath my car but i cant say that it isnt leaking for sure.
Last edited by Sachemhockey44; Apr 18, 2014 at 10:00 PM. Reason: Automerged Doublepost
Old Apr 18, 2014 | 10:51 PM
i didn't mention before, but i have no lights on on my dash indicating any problems with the power steering...would i have a CEL or a light on the dash if my motor has failed??.....also could it possibly be a blown fuse?
Old Apr 19, 2014 | 01:16 AM
During the recall they replaced the assist motor because it would act up.
You may or may not get a power steering error code, depending on the exact failure. There is a big fuse, 60 amp I believe for the EPS system motor. Check that.
There won't be any fluid leaks because there is no power steering fluid. The assist motor is inside the car anyway, under the steering wheel over the pedals.
Old Apr 19, 2014 | 10:22 AM
okay thanks for the help, it seems the power steering motor they replaced during the recall has crapped out on me.....typical
Old Apr 19, 2014 | 10:38 AM
Im going to check the EPS fuse today... if you don't mind, can you tell me which fuse it is? i know the fuse box is under the hood I'm just not sure which is the EPS fuse...thank you
Old Apr 19, 2014 | 10:18 PM
10 seconds on google showed me this
turbochargedss2012
Sep 20, 2023 12:17 PM
Solaris99
28
Mar 15, 2017 01:22 PM
TedSS
26
Oct 10, 2015 04:30 PM
importkiller
Sep 30, 2015 07:18 PM
