Steering wheel crooked
Old 11-10-2015, 01:19 PM
Gugi96's Avatar
So i installed new control arms front and right and my steering wheel is slanted to left, my tires also spin really easy now and my steering wheel shakes and makes noises when i get around 60 mph. Anyone know of what it can be. I double checked everything and tightened the bolts tight
Old 11-10-2015, 01:28 PM
Gugi96's Avatar
I probably shoudlve posted this sonewhere else lol
Old 11-10-2015, 01:36 PM
chevygirl2006's Avatar
I really hope someone answers this because mine has been doing the same thing for a long time.
Old 11-10-2015, 01:45 PM
Did you lock the steering rack prior to installing the control arms? And did you let the axle drop when you moved the knuckle to get the control arm out?
Also what does tightened the bolts tight mean? Did you torque them to spec or just what felt good?
Old 11-10-2015, 01:52 PM
I would assume that you haven't done the alignment yet huh
Old 11-10-2015, 02:08 PM
Administrator
Administrator
Staged07SS's Avatar
**Thread moved to correct section**
I've removed and reinstalled the control arms on my car twice, and never had the steering wheel go off center.
Removing and installing control arms shouldn't affect the steering wheel alignment unless for some reason you unbolted the tie rods, messed up an axle by over extending it, or not bolting to the correct torque values.
Do not, and I repeat do not go for an alignment until you verify the installation of the control arms is correct, and no parts were damaged, ie. axles/tie rods/etc.
Take some pictures of the your install if you can. Might help us determine an issue you might be over looking.
Old 11-10-2015, 02:13 PM
South Central *********
JapEatr's Avatar
if the knucle is take loose from the strut mount then the camber will be off, which in turn mess with total toe
Old 11-10-2015, 02:17 PM
Administrator
Administrator
Staged07SS's Avatar
Shouldn't be messing with the knuckle to strut mount for installing the control arm. Not needed for removal or installation, but anything is possible, that would def cause an alignment issue.
Old 11-10-2015, 02:27 PM
Maybe I should try an alignment lol
Old 11-10-2015, 02:28 PM
Best thing now is yeah verify everything was installed correctly although kinda hard not to install correctly, make sure the bolts are torqued to specs tho. When I did mine my steering wheel stayed in place as well but I did change tie rods, springs struts and all that stuff so I needed the alignment
Old 11-10-2015, 02:33 PM
Administrator
Administrator
Staged07SS's Avatar
Everyone on here thinks an alignment is always the answer without first inspecting the suspension and steering system first to verify it is functioning correctly.
If your car is doing what the OP's is doing, I highly recommend you inspect your car first.
Absolutely... when you mess with the actual suspension geometry like that.
Old 11-10-2015, 02:37 PM
My bad I assumed people would check the stuff first before going to get the alignment. Of course no point in doing the alignment if a part is not installed properly or is not working properly. Always inspect everything before doing the alignment
Staged07SS (11-10-2015)
Old 11-10-2015, 02:40 PM
Administrator
Administrator
Staged07SS's Avatar
You would think
Old 11-10-2015, 02:41 PM
Lol what happens when you worked on cars it's just an instinct for me to check
Old 11-10-2015, 02:45 PM
Administrator
Administrator
Staged07SS's Avatar
Me to!
Old 11-10-2015, 05:12 PM
I didn't change anything though besides new wheels. And I've never had an alignment. Even after being on lowering springs for 3.5 years.
Old 11-11-2015, 03:17 PM
firehawk618's Avatar
This is generally true however if someone had the alignment adjusted to compensate for really bad LCA bushings then it's conceivable that putting on arms with good bushings could make things go out of whack.
Right?
Old 11-19-2015, 05:41 PM
Gugi96's Avatar
I didnt mess with tie rod but i couldnt get to fit so i had to pull the whole assembly (rotor,strut,sway bar endlink,axle) which i think i might fucked up because i had to pull it really hard side to side which now that i think was really stupid, it was really easy to take out but it wouldnt fit easily when putting new ones in
MP81
10-27-2023 02:10 PM
SpeedyGonzalez
11-11-2015 05:38 PM
Cuda009
11-10-2015 07:08 AM
Marcov223
11-09-2015 12:16 PM
SECRETARIAT
10-26-2015 09:30 AM
Quick Reply: Steering wheel crooked
