Steering wheel not aligned properly?
Old Sep 16, 2008 | 12:02 AM
Super_SS's Avatar
there is a bolt by the steering wheel shaft to adjust the wheel..have a tire shop do it..some one has to hold the wheel straight so they can loosen the bolt and then tighten it back so the wheel stays straight
Old Aug 13, 2010 | 03:10 PM
originaladrian's Avatar
i need to know where this bolt is
Old Aug 13, 2010 | 04:58 PM
dspeed123's Avatar
Under the dash on the top of the intermediate shaft. 13mm head. Have blue loctite handy for when you put it back together after you clean the surface of the bolt and have your steering wheel lined up.
Old Aug 13, 2010 | 05:33 PM
thank you
Old Aug 17, 2010 | 09:50 PM
aterminatorz's Avatar
My car started doing this after the dealer did the power steering recall. Sometimes the wheel shakes back and forth when I take my hands off and it pulls left.
Old Aug 18, 2010 | 11:35 AM
you need a proper alignment and wheel balance. the problem were having is the car is aligned but steering wheel not straight. you have a completely different problem that should be taken care of asap or your tires are going to go to ****.
Old Aug 18, 2010 | 06:53 PM
I'm not sure. I do have to hold the wheel slight right for the car to go straight on the interstate. Maybe they did not have the steering wheel straight when they installed the steering motor? I never noticed the problem before that recall work was done. Could it be possible that they forgot to torque the lug nuts to spec? I did notice that the tires are not wearing evenly.
Old Aug 18, 2010 | 11:11 PM
WhiteSSBalt's Avatar
Not a Sebring
Good to see a thread I made in 2008 is still going strong
Old Aug 18, 2010 | 11:36 PM
[QUOTE=aterminatorz;5171081]I'm not sure. I do have to hold the wheel slight right for the car to go straight on the interstate. Maybe they did not have the steering wheel straight when they installed the steering motor? I never noticed the problem before that recall work was done. Could it be possible that they forgot to torque the lug nuts to spec? I did notice that the tires are not wearing evenly.[/QUOTE
lug nuts wouldnt do that really. a wheel weight could have been knocked off but i doubt it.
it sounds like your car just fell out of alignment. see if maybe they would do a free one.
lol i love when that happens
Last edited by originaladrian; Aug 18, 2010 at 11:36 PM. Reason: Automerged Doublepost
Old Aug 20, 2010 | 12:13 AM
xxxxsh4d0wxxxx's Avatar
Um.. If the wheel is crooked and you're still going straight, and it doesn't pull.. That would be a toe problem. Aka, alignment. Mine was like that also, as I bought the car used. I work at a dealer. Had one of the techs look at it. Threw it on the alignment rack. Boom. Fixed.
Old Aug 20, 2010 | 10:03 AM
  #36
dspeed123's Avatar
Normally it would be an alignment issue but everyone here has had a proper alignment and or had the steering recall done so they know the alignment is good. It is quite simply that the tech who replaced the unit did not mark the placement on the intermediate shaft and the splined shaft of the steering column (I mark the rack shaft and lower intermediate shaft as well) with a paint marker prior to uninstalling and transfer those locations to the new unit. It happens all the time with inexperienced techs. The bad thing is that if you don't know cars the loaded spring that is in the steering column can break very easily if it is too far off from center and then its getting replaced a second time. Generally, most people shouldn't mess with this if they don't understand what could happen if they do this improperly.
Old Aug 20, 2010 | 10:18 AM
  #37
06G85's Avatar
I noticed a few weeks ago that my car pulls to the left slightly when I have the steering wheel straight. But my alignment in fine.
Also, when at a stop light, I center the steering wheel and hit the brake my steering wheels turns too. My brakes are fine and I DO have a LSD.
Old Aug 20, 2010 | 10:28 AM
  #38
dspeed123's Avatar
Not gonna lie, it sounds like a sticking brake caliper to me. As long as you are sure that the alignment is good.
Old Aug 20, 2010 | 03:06 PM
  #39
wantedSS/TC's Avatar
yup, that's a bad caliper if the car pulls a certain way when braking.
not too expensive to fix. just need a new caliper.
Old Aug 20, 2010 | 08:16 PM
  #40
06G85's Avatar
Hey guys, I just checked it again today, it doesn't turn. And it wasn't turning while braking, I was at a dead stop, had my foot OFF the brake, then applied the brake and my wheel turned a little bit. Maybe rivets in the road? But the car is fine.
Old Aug 22, 2010 | 05:09 PM
  #41
DC02's Avatar
yeah when my wheel is slightly left, i mean BARELY left, it tracks straight. The alignment is fine though because it was checked by myself and slightly adjusted by myself, I think this is just a fit issue. I've heard arguments it is because of the road crown but its just the wheel needing a slight adjustment. I dont think anyone else seems to give a **** enough at the factory or repair shop to check that **** though. Might be a time consumption thing. Its not a major issue, just slightly annoying once in awhile. Drive predominantly with my left hand so it doesnt bother me as much.
Solaris99
28
Mar 15, 2017 01:22 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
TedSS
26
Oct 10, 2015 04:30 PM
DANRICKARD
Oct 1, 2015 12:08 AM
