Stereo is possessed
Old Jan 22, 2006 | 12:22 AM
Notsosane's Avatar
Stereo is possessed
I went to the movies last night and when I got out and started my car the radio was completely f@#$%!. I have to listen to the same cd over and over at the same volume. When you try to eject the cd or push any other button for that matter it just shows the time left on whatever track is playing on the cd. Every now and then you can adjust the volume with the steering wheel controls. And it beeps all the frikkin time. Anyone else had anything like this happen?
Old Jan 22, 2006 | 12:58 AM
DJNateGnau's Avatar
To stereo: THE POWER OF NATE COMPELS YOU! THE POWER OF NATE COMPELS YOU! LOL.
Old Jan 22, 2006 | 01:22 AM
Malaclypse's Avatar
Time to have it sent out for repair. Either that or GM can order you a radio and let you retain your malfunctioning stock one.
Old Jan 22, 2006 | 01:29 AM
bowtiess's Avatar
your rides jealous of ur ladies, its like christine, if you have seen that movie
Old Jan 22, 2006 | 01:44 AM
WopOnTour's Avatar
There is a revised software for the Cobalt base CD radios w/o MP3 (RPO U1C)
Have your dealer look up TSB #05-08-44-010B
The revision is designed to rectify the following, possibly intermittent, issues:
• Inoperative or "dead" CD mechanism
• CD loads but won't play
• CD spins but no audio is heard
• Radio clock displays 12:00 while CD plays
• Radio VF display does not dim when the vehicle dimmer control is decremented
• Radio VF display momentarily flickers
• Radio VF becomes inoperative
• Radio displays ERR
• Radio displays LOC, disabling the radio
You can also try resetting the radio as follows:
1.Turn the IGN OFF.
2.Remove the right side lower console trim panel.
3.Remove the 10 amp Radio fuse from the IBCM (aka fuse-block)for 30 seconds.
4.Reinstall the fuse and turn the IGN ON.
*You may have to reset your radio presets after performing this procedure
HTH
WOT
Old Jan 24, 2006 | 11:05 AM
M-Dub's Avatar
My Radio is acting weird too.... It will pop up with an error, on a CD i have been listening too for weeks, and when I try to eject the CD it says, "NONE"! I have to take the car in to get a new catalytic Converter put on anyway, I will let them check the radio to while it's there!
Old Jan 24, 2006 | 03:45 PM
WopOnTour's Avatar
Which radio do you have?
Is this a retail CD or a home-burn??
MP3s???
WopOnTour
Old Jan 24, 2006 | 10:15 PM
Notsosane's Avatar
It's a home burn ..the only cd's I'm gonna pay for are gonna be blank. I have the XM capable cd player.
Old Jan 24, 2006 | 10:27 PM
djpatrick35's Avatar
My radio does the exact same friggin' thing! Tell me what they did to it.
Old Jan 24, 2006 | 10:31 PM
brianm01's Avatar
I got a base cobalt coupe and I have the same problem, to get my radio to work I have to turn my car off, open the driver's door and close it, and start my car back up again. It is not a consistant thing with my car but I plan on taking it to the dealer to get it replaced.
Old Jan 25, 2006 | 10:02 AM
M-Dub's Avatar
nothin' yet... they still haven't called me telling me my new catalytic converter is in... I am gonna tell them about the CD player when I am there... I have the base 05 balt... it has the basic CD stereo in it.... But for me it does it on both... home burns and store bought!
Old Jan 25, 2006 | 01:43 PM
I also have a base coupe with the baseline stereo...It appears to be a pattern! Keep us posted when you take it in. 90-percent of the time, it works fine, but it pops up out of the blue every now and then for me with the "None" message. How about you guys?
I once had it happen when I was listening to a CD, pressed the eject button, got the "None" message and then it wouldn't work until I shut off the car.
Old Jan 25, 2006 | 03:41 PM
Steeltown Pursuit's Avatar
I've posted a couple times about this exact problem. I too have a base (pursuit) with the base cd player. I'm taking it in for the second time tomorrow and hopefully they will replace it with the mid level one. I heard that is the way to fix the problem.
I just had it replaced and then two days later with a brand new deck (same base cd player) it happened again!
I'm hoping i'll get the mid level one to at least have the multi line display and auto eq settings. I hate how the base stereo only has one line of output ... it's so basic.
I'll post again if I get the newer model deck or still another crappy base one.
Old Jan 25, 2006 | 04:13 PM
Cobalt443's Avatar
when i had my base cobalt, the dealership ordered me a new radio with out any questions asked
Old Jan 25, 2006 | 04:55 PM
RedBaseBolt's Avatar
My stereo has the same problem with the intermitand ERR and NONE issue. I know my dealership will just tell me to suck ***** though if I complain about it. I should never have bought my car there... grr
Old Jan 25, 2006 | 05:29 PM
tylerwear423's Avatar
I had a similar problem with my base model radio just three weeks after getting my car. The dealer gave me the next radio up for free because the base models were on back order haven't had any issues with it.
Turbo6
Sep 30, 2015 09:14 AM
Extreme Dimensions
Sep 24, 2015 07:51 PM
Turbo6
Sep 24, 2015 04:15 PM
RyGuy
Sep 21, 2015 10:03 PM
Turbo6
Aug 27, 2015 08:37 PM
