Stereo Problems:/
Old Sep 17, 2011 | 07:25 PM
BoostWhore's Avatar
Stereo Problems:/
When its cold out my radio doesnt work......my speakers make a "popping" noise............it does it when its under 50 degrees. SOMETIMES if i have my ipod on and a good bass song before i start my car it doesnt make the popping noise....i was just wondering if anyone else had this problem or what i should do.
I have an 07 ss if that makes a difference
Old Sep 21, 2011 | 01:35 AM
Phil424's Avatar
This is a big problem with the cobalts. I have actually upgraded the stock speakers and while I was in there I found what the problem is. The stock connectors that actually plug into the speakers are quick connect and for some reason after awhile they begin to short out. I just cut the connector off and crimped it and have not had a problem since. If you take your door apart and wiggle that connector you'll see thats where your problem is.
Old Sep 27, 2011 | 12:31 AM
BoostWhore's Avatar
thanks man but idk why it would only do that while its cold:/ and by no means would i ever be that smart to figure how to take the door panel off
Old Aug 18, 2012 | 04:40 PM
Tanner Lephart's Avatar
the door panel is easy to take off. its two screws and then just pops off. the screws are behind the door and and the part you grab to close the door. after removing those two screws the door pops off easily.
Old Aug 18, 2012 | 06:53 PM
Coblasts's Avatar
The connector issue in the cold is caused by contraction of the plastic connector ,if the two connectors are of a different type of plastic one will contract more(get smaller) than the other and will become loose.
But then they could be poor fitting from the start,or getting corroded from moisture.
Turbo6
Sep 30, 2015 09:14 AM
Turbo6
Sep 24, 2015 04:15 PM
soundjunky
Aug 28, 2015 03:24 PM
Turbo6
Aug 27, 2015 08:37 PM
stealththx
Sep 3, 2005 03:00 AM
