still having electrical problems
Old Jan 30, 2009 | 05:13 AM
impulseballer's Avatar
ok guys basically i had a problem before hand where my battery just died. I kept having to jump it after a day of not driving etc. when the car was on tho it kept running and the voltage was around 14 volts. i got a new battery and a few days later same thing happened. im just wondering, could it by ne chance be the alternator or was the new battery I got no good? i will eventually get both tested jw what you guys thought. i don't think my amp is staying on and draining it i just don't know it's annoying the **** outa me.
Old Jan 30, 2009 | 07:28 AM
Coblasts's Avatar
You have something draining the battery,Try unhooking the Amp for a couple of days and see what happens.
What else has been wired into the car?
Is your trunk light staying on?
The car has a power saver mode so what ever it is I would think has to be wired directly to the battery.
(Amp maybe)
Old Jan 31, 2009 | 12:19 AM
Sumasianluv's Avatar
could have drained your battery by having an accessory on, if it were to be an alternator problem i would imagine ur car dying while still turned on and working, could be ur starter, its solenoid not getting juice cuz its windings are weak, or a loose/weak connection somewhere, thats my thoughts.
Old Jan 31, 2009 | 08:59 PM
it's gotta be my amp setup bc i know about the power saver mode. the amp is cranking 14.9 volts as i checked it last night when the car was on and running. tomorrow when i wake up from my night shift tonight im going to disconnect it and see what happens.
Old Jan 31, 2009 | 11:25 PM
Zander916's Avatar
I had a similar issue on my 08 SS. I was told by the dealer that there is a "body module" that detects inputs such as windows, door locks, power outlets, etc. It will stay on for some time after the car is shut off and then turn off if there is no activity.
I had something that may draw minimal amounts but they indicated it would keep the body module powered which might drain the battery.
I'm skeptical of that whole idea myself. I mean just it having enough power to drain the battery overnight or in a day or so.
But food for thought anyway.
Old Jan 31, 2009 | 11:27 PM
yeah if i drive my car every day it's fine. if i don't for 2 days or more it doens't have the juice to start.
Old Jan 31, 2009 | 11:45 PM
hmmm well whatever the problem is hope u find it and fix it, good luck bro
Old Jan 31, 2009 | 11:49 PM
thanks man. yeah im going to the city next weekend so im going to unhook the subs and amp and see if she starts after 3 days of no running.
Solaris99
28
Mar 15, 2017 01:22 PM
ernnyyes
Oct 2, 2015 05:16 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
